I did, it was working fine the whole time, only this morning it was changed into 7000. I even did a race yesterday without any problems. The question is why did it change by itself?
This is surely the same issue that others began having after a behind-the-scenes update in Companion, as documented in this still-unresolved thread:
From what I’ve understood through reading the various entries in that and other threads, there’s a clash between the formats of the weight data in two different Zwift instances for people running on devices that are in certain languages that aren’t English.
People seem to be having success with the workaround where they modify the weight as mentioned by James (above) in one platform, and then not opening/modifying the weight field elsewhere. No idea why you would just get it now, but you’re far from alone.
Like the German language bug in Companion that has been known about since Dec 2021 but still not resolved, this one seems to be blocked in ZHQ’s bug-correction process because they don’t have anyone who can competently work on issues related to Zwift/Companion running in a non-English language environment and rely on low-capacity AI to do translation with, apparently, no checking by human eyes and brains.
As Roule pointed out, the Companion app shows 70.00 kg as 7000 kg with some language settings. As long as you don’t change your weight in Companion, you’ll be fine. Just viewing the profile info and pressing Save counts as a change (adding those two extra digits) even if you don’t touch the values so don’t do that, press Discard instead. And yeah, this is just beyond embarrassing.
The problem is indeed in the companionapp. I have checked it. I’ve changed my profile pic in the app and everytime i access my settings through the app it changes my weight to 7000kg.
I does not work. Every time, when I click Save, weight is changing. Any problem on Iphone, but I dont try to ride.
It’s a known problem when changing your weight in the Companion app for some languages. Change your weight properly in the main Zwift app and it will be fine.
I need to use ZC to connect BLE sensors, and I was trying your solution earlier, every time weight was multiplied by 100. I will use Iphone, there is no problem.
you can use the ZC app, but just avoid editing your profile there, since it adds two zeroes to your weight every time you hit the “Save” button… Edit your weight in the Zwift app and to be on the safe side, don’t even look at your profile in the ZC app.
I just had my first ride with my newly bought Kickr Bike after having setup Zwift on my PC. Everything went smoothly. I have created my profile and entered my weight (solid 110 kg) and height (186cm). I have seen that the weight is saved as 11000 kg which I found weird, but perhaps the dot is missing and it should rather say 110.00 kg
Now I had my first ride and if I have 110 Watts it should say 1.0 w/kg or am I wrong? But it rather stated 0.6 w/kg and it was not a pleasant ride. I mean I know that I am not fit (major reason to having bought the bike and entering Zwift). But this felt as I was pulling a caravan.
I have entered the weight multiple times via different options (website, companion app, windows app).
Perhaps I misunderstood the calculation of w/kg and I am the least fit person on Zwift. Any suggestions are appreciated.
This is a known bug, but it should work ok if you enter your weight in the Zwift app itself and not in Companion.
Thank you. I opened the above text as an own topic and it has been merged into this thread. I was pointed here and it is working fine now. I am no longer pulling an elephant.
Thanks again
Sascha
Especially since they don’t seem to sync appropriately, especially if you’re going in and out of events.
Mad how this hasn’t been fixed yet. Imagine all the people that don’t frequent these (or any) forums.
Has anything changed this month in Companion in Android with respect to this bug?
I’m on iOS and today I noticed that weight entry is back to its pre-April limitation of whole kilograms. It’s the same in the zwift-dot-com profile settings. I can see two decimal places, but the system only allows them to be « .00 ».
(For those not reading the whole thread: from around early April we were able to enter weight in kg to two decimal places, but that coincided with the problematic issues in this thread appearing.)
Edit: I just checked the setting in game, in the profile page accessible on the old UI in the “pause menu”, and it seems that it’s still possible to enter weight to two proper decimal places there. That new data is then updated to Companion, but in read-only form, i.e., any Companion editing takes us back to the .00 kg limitation.
I’ve been entering my weight to 2 dp in the Companion App in Android and it’s been working fine.
The numbers aren’t what I’d like them to be, but they are translating across to the game.
The solution…you go on Zwift site…you put your weight in kg…and all is ok !
On companion…your weight is still *100 but it does not modify resistance during training…
If you change your weight directly in companion APK…it does not work
Didier
Seems this rather trivial number formatting bug is still open. I still have people reporting me this issue even though there is a workaround.
