Trying Understand - Race Score +/-
When I started racing anytime I podium my score would jump pretty dramatic but when I did not it would usually take a hit. Just trying to understand why on the race I did today DRAFT and I podium silver in CAT D I did not see my score move at all? In some ways may be good cause in the past I would keep going between two race groups of 0-180 and 180-350 and now it seems they got rid of the 0-180 group?
Team Draft races that are not racing score races(Sat, Sun, Mon, Tue) don’t count towards racing score unless you do a 5 minute PR in them.
Thanks I actually did a 5min pb but maybe I am misunderstanding. The race was fun and short after recovering from flu.
Probably cause no racing score race it may not even care about the 5 min pb.
It does care about the 5min PB, any activity on zwift counts for that, but that doesn’t directly impact your score.
What it does is recalculates your seed score, and from there your floor score which is 15% lower.
A PB will only move your score if the new floor is higher than your score had been.
I cannot find an answer to this specific question anywhere so here goes. I’ve done two ZRS category races recently. Both times the same thing happened with my score. The results page showed a change in the score to one value, while the score on my profile page changed to an even higher value. Why?
It’s related to the new change that moves your score up to seed with a 5min pb.
The results list shows how your score moved from that race, the move to seed doesn’t seem to be processed until you end your ride, which is obviously some time after the end of the race. So it shows as a new value on your profile but is not reflected in the results.
Thank you. Makes sense. I had new 5 min PBs in each of those races.
