Hello ther…
I have a problem with the connection of Ttrainingpeacks and Zwift.
The customized workouts do not appear anymore in Zwift. In the past, they were loaded into a spesific folder as custom workouts which are structured in Traningpeaks. This folder disappeared from the list of workout folders in Zwift.
I tried to disconnect TP from Zwift website and Zwift Companion and reconnect, but still, the TP workouts are not showing. I even, Uninstalled TP, Zwift and Zwift Campanion and reinstall them, but the problem was not solved.
I searched on the internet and Google to find a solution, but nothing was useful.
Can anyone help me with this problem
Same for me. Just schedule a workout in TP and it appeared neatly in a TP folder in Zwift on the scheduled day. Not any more though…
I also used to be able to use the “category” tag to sort all custom workouts into custom folders - but that stopped working at the same time. They now just appear in a big, unhelpful mess.
I am having the same problem. About a week ago my TrainingPeaks folder just disappeared from custom workouts. I have followed all of zwift supports suggestions, but they really aren’t that helpful.
Which support suggestions did you follow?
Hi @Matt_Whitacre welcome to Zwift forums.
Shuji at Zwift HQ here. Peeking at your server logs and I’m seeing you log into Zwift from an Apple TV and maybe two different iPhones without ending each session. No doubt you’re trying to troubleshoot on your own, but having multiple sessions open at the same time can manifest in symptoms like yours.
If the Apple TV is your main Zwifting device - save & end (or trash and end) after each session, and also force-close the app. This is how you force close Apple TV apps. Doing that each time will minimize any issues with data uploading, or syncing with third parties like Training Peaks.
I’d also recommend you uninstall the main Zwift game app from your phone(s) to make simultaneous logins a non-issue.
Apple TV users can and should use the Zwift Companion app on your smartphone so that you can pair more than 3 Bluetooth devices to ATV.
Would you try those things and let us know if your workouts sync again?
I jjust did everything you suggested. Forced closed the zwift app in appletv, deleted the app off my phone. Connected using the companion app. I am still having the same problem.
All on this thread - when update to Zwift game version 1.66 when the phased rollout is available to you.
@Matt_Whitacre in particular - please report back if v1.66 solves your issue?
