Hi, I think this is an old problem. I have tried disconnecting and reconnecting a few times, do I just need to hold tight and it will resolve itself?
Do you mean syncing your Zwift rides to TP, or your TP workouts to Zwift?
I had never problems from Zwift to TP.
If you want to see your TP workouts in Zwift, search in forum, there are some informations about, for example:
One thing to note: only that day’s workout will sync.
Also, TP workouts must be time-based in order to sync correctly.
Hi, syncing both ways. I cant find the zwift activity in training peaks even though both say they are connected. Should it go directly to my calender?
I look in the forum for getting training peaks workouts in zwift.
Thanks so much
Enda
My Zwift activities show in calender, had just 2 fit-files uploaded manually (Zwift did not save the activity). Had never changed anything, started Dec 2018.
But I think your first should be disconnect and connect again. Would it be possible you are logged in Zwift on more devices (PC + cell phone)? Just an idea…
No more ideas, sorry.
Great thanks guys, I got it working once I cleared the cache.
