Apologies if some of this is a repeat (I did search the forums first…). I would like to propose some improvements to the TT format.
- It would be good to have TT position based on the those on the road at the split timing points. The current timing means little to how you pace the race.
- It would be good for the splits to compare with your fastest time recorded time on the route. Especially as TT courses are limited at present.
- Any chance split time could be listed on the activity page? This way if automating the cross check with your PB is impossible, you could record your times and compare in race.
- I think TT is one of the best means on Zwift to assess performance improvement as you progress your cycling fitness. It would be good if this personal TT comparison could be included in the UI.
Thanks for reading!
