Hello forum. I’m using the above trainer, combined with the Garman V2 sensors, and struggling to find a setting which gives anywhere close to accurate power/speed readings in Zwift. I can get the power tracking pretty accurately, but the speed is around 30% faster in game than on the Flow computer. I know the T2200 isn’t officially supported by Zwift, but I wondered if anyone else is using the same setup and been able to get a good setup?
There are many factors applied in zwift to generate your virtual speed, weight, height, frame, wheels, surface, gradient, drafting etc etc etc
As long as you power matches accurately then you should consider yourself as accurate
