On group rides where fence is used you can find yourself too far head of the pack to be able to get back before counter reaches zero. For example if you have crested a hill and the pack are still on the ascent. It would be helpful if the fence recognised riders not pedalling/emitting zero watts (ie genuienly trying to get back) - and were excluded from the cull. Obvs when fence passes they could start pedalling again. This would also mean that goup leaders wouldn’t need to ‘flash’ the fence.
Yeah no…
If you’re ahead of the fence that far for going that hard and leader is using fence, most would hope it does its job and removes you from the ride.
Pushing through the fence on climbs encourages others and ruins the pace for everyone in the back.
This would only encourage the behavior leaders are trying to avoid with the fence.
Find a ride where the leader doesn’t use a fence if you (the reader) disagrees.
It’s there for a reason; respect the ride.
I have probably done a thousand group rides, and have never been kicked by a fence. In rides with a leader using a fence, I take the hint and ride with the leader, or do my efforts behind the group with the sweeps.
If you want to find rides that don’t use a fence, you can do that in the ZwiftHacks Events page. Sadly Zwift does not give you a way to search for it, and of course the leader may choose not to use it even if the feature is on. DWGZ and BMTR rides are not fenced, if you see any of those at a convenient time.
