Shots to Fire
When doing MTB training plans it often says “activation sprint” when warming up but it always gives me a power so I use ERG mode.
Currently doing Dirt Destroyer, Week 5, first workout “shots to fire” looks like you have three blocks of 30 second sprints increasingly adding more power each block (if using ERG mode). My question is the description of the workout below leads me to believe I should going “all-in” or maxing effort. Should I use ERG mode and do the power in the workout or do the workout more like the description states??
This workout really works your top end - your anaerobic capacity, which is your ability to make really hard efforts.
In mountain biking, to get up a short steep climb, or to get through some mud or over roots, the best way is to do it quickly - lots of power for a short period of time.
This session gets our anaerobic energy systems firing, as we make repeated 30 second efforts which increase in intensity through the blocks.
Don’t be discouraged if your power drops throughout the blocks. You’ll burn a lot of matches as you progress through the session, so just try and hold on as long as you can as you will still benefit from the effort.
In the same fashion - don’t go out too hard! This is a fairly long session, so in the first block, just do what you need to do, 140% of FTP and no more.
I’d go with the power targets over the comments in the workout, but many trainers can’t handle quick resistance adjustments for 30 second sprints so depending on the responsiveness of the trainer I would be inclined to turn off ERG mode for a workout like this. Anaerobic efforts don’t necessarily mean all-out sprinting. It doesn’t sound like it’s encouraging you to do an all-out sprint.
i followed the workout and it was plenty tough, thanks!
