Dears,
Anyone can help?
Driving through Alpe du Zwift, I can’t see sector stats on the left side as in the photo in the top. Always displaying time of each sector, avg HR etc.
Currently, when I start a segment after a turn nothing is displayed on the left side of the screen, just my best PR in the last 90 days or leaderboard as below.
Hello @Kamil_R welcome to Zwift forums.
Shuji at Zwift HQ here. Thanks for the report, and also the second screenshot. It is always helpful to see what you’re seeing on your end.
We have not had other reports of this issue on Alpe du Zwift since 1.68 released last week, but I’ve flagged this up to team for investigation.
@Kamil_R
Would you check your in-game settings? Do you have Leaderboards set to “Always” or “Auto?”
Always. Should I change it on “auto” and then check?
Sounds similar to this report about the climb portal HUD
@Kamil_R
Yes, please, try it on “auto.” This should make the Alpe sector UI appear instead of of forcing the KOM leaderboard. Would you report back after your next attempt? We’d love to hear that solves it for you.
„Auto” - helped.
Solved.
Many thanks
I’m running version 1.92.2 and not seeing sector stats on the alpe. Also, Leaderboards is not an option under Preferences.
Thanks!
