Why not just a “soft rubber band” to opt into?
Something that allows you to be banded to a bot assuming you’re within say 0.1-0.3w/kg of its pace at any given moment. (Assuming it knows what is required for you to stay with that bot… as some of you here already know, for some of us it takes closer to 3.0w/kg to stay with Coco at 2.7w/kg, but let’s ignore this for now.)
This would allow folks to push out, or fall out, once they fall outside of that spec; so it can’t be abused (ala how Teleport and Ride with a Friend works, where it locks you in for 10 seconds… but if you don’t pedal, you get dropped).
I think enough folks on Strava probably get upset by Zwifters and their unrealistic ground speeds, so they can be ignored already; but is this really any different than using Coffee Break, covering ground at an unrealistic speed for your power?
Anyways, just an idea…
As the link shared earlier I think everyone knows how I feel about anyone adjusting their height and weight outside of their real world measurements, as it’s only “cheating” to yourself. (you can forget to alter it if you do change it, and it can confuse anyone with their behavior of going up or down hills after being corrected)
So why not a system that is:
- opt-in
- not rigid
So not as ridiculous as rubber-band rides where you have folks across the board in power; but something that is more like a “non-drop” ride with friends… You get helped back to stay with the group, but if you don’t or can’t do the work, then it just won’t happen and you do get dropped.
But if you don’t want to get tied to the bot… you don’t have to accept it.
I once again imagine this as a pop-up “you’re riding with this pace partner; tie on?”
Another thing this could help with is if you’ve ever run across an RP, and want to ride with them after doing whatever, but you don’t know what route they’re on, it should be able to correct your pathing to theirs so you don’t have to be concerned with choosing the correct turns at every intersection. (As the only other solution here still would be to end your ride, return to the main menu, and join the RP from there after you… spend 3 minutes trying to find whichever RP that was on the poorly organized main menu)
