Rider Stats from Strava
Rather than having to update items like my rider weight in Zwift, if you’ve enabled the Strava connection, have Zwift pull that data from Strava at startup time.  Then I only need to update in one place (Google Fit) and it will flow down through all my account.
Rider height would be the same (but this isn’t something that I change often (i.e never).
It could pull the data from iOS’s HealthKit (perhaps with a rolling 30-day average weight applied to weed the outlier measurements).
I have a Withings connected scale so the data is readily available, and there are other such connected scales- Fitbit Aria, Garmin Index, Wahoo Balance, Polar Balance, Withings Body Cardio, iHealth Core, etc.
