Since the last update the map is not centred correctly. Instead, the rider is shown at the top of the map, under the transparent metrics panel. I cannot seem to re-centre the map or give thumbs-up to nearby riders.
Companion App? If so … I’ve had the same.
Close and reopen. It’s a nuisance workaround but you only need to do it once.
ETA: Android if Zwift HQ are looking in
Sounds like this issue
As David said. Except I just (companion app) go to home screen, then return to game screen. Back to normal. @Adam_Woolstencroft
I’ve had that happen a few times recently too, I force close the companion app and then it is fine… also on android
RESOLVED – Thanks for your responses. I tried closing and clearing the cache. In the end, going back to the home screen and then back to th game screen worked for me.
