Hey folks,
This post is give you more detail on an imminent feature we mentioned in our Competitive November recap post: your power and recommended category information on your Zwift profile.
In about 2 weeks - provided all goes well - we’ll have the first step to more visibility on how your minimum recommended category is being determined. Read on for more detail.
Where can I see my info?
Once released, you’ll find your power information on Zwift web, on both your activity feed and your specific Zwifter profile. This means you can see your information at either The at Home Cycling & Running Virtual Training App or The at Home Cycling & Running Virtual Training App, where “ZWIFTID” is your ID. The second is accessible via the “My Profile” button on the top right of your information in the activity feed, as shown below.
This will be in English first, with localization to follow shortly after.
Neither the activity feed nor your profile are publicly visible to anyone. You are the only one that can see your power information.
Initially, this information will exist only on Zwift Web. We will then have the information available on Zwift Companion in the future.
We will not be integrating this information into ZwiftPower due to technical considerations, so there will be still be some discrepancy between your Zwift category and your ZwiftPower category as there is today.
What will I see?
You will now be able to see the following information on your Zwift profile, in order from top to bottom:
- Suggested minimum category - the lowest minimum category you can join for a Zwift race with Category Enforcement enabled
- zFTP - our best estimation of your FTP based on your data
- zMAP - our best estimation of your MAP based on your data
- VO2max - our best estimation of your VO2 max based on your data
- Critical Power - your best recorded critical power values for a given interval of time in Zwift, starting at 5 sec and extending to 30 min. Keep in mind these are not the sole values we use, merely what we found most relevant to display to Zwifters in the first iteration.
Here is an example screenshot:
All numbers in this screenshot are not from a real profile, and are made up solely to provide a visual example.
When you click on “More Info” you will see a more detailed explanation of the information on your profile, as shown in the below screenshot. You will also see what date and time your critical power values were registered, helping you pinpoint the activity should you need or want to.
If your chosen gender in Zwift is female, you will also see the information specific to the women’s categories in addition the non-women’s categories.
What is used to determine the numbers I see?
We record every activity you do on Zwift on a 60 day rolling window, even if you don’t save the activity or the activity is deleted. That means that every time you ride on Zwift, whether it’s a workout, race, group ride, free ride, or anything else, we record your power to get the most accurate profile of you as a rider. This is then used to determine the above points (minimum category, FTP, VO2, MAP, and critical power). We do not use ZwiftPower calculations, though they are close to one another.
For a more detailed breakdown, check out this article on our support site.
If you have an activity that you feel is causing your power information and category to skew too high, please contact our support staff.
The Release Plan
We will be releasing this information according to the following plan:
Step 1: On Zwift web in about 2 weeks - as mentioned above - on both your activity feed and your specific Zwifter profile. This means you can see your information at either The at Home Cycling & Running Virtual Training App or The at Home Cycling & Running Virtual Training App, where “ZWIFTID” is your ID. The second is accessible via the “My Profile” button on the top right of your information in the activity feed, as shown below. This will be in English first, with localization to follow shortly after.
Step 2: Following the web release, Zwift Companion will also have your power information, located on your Zwift profile page. We will have more information on this in the coming weeks, as we’re currently working through the designs.
We will not be updating ZwiftPower with the same information due to technical considerations.
If you have questions or feedback, let us know in the comments below.
We’ll be locking this thread in 14 days to keep feedback pertinent to this update.
