Power meter on spin bike
I’ve been using Zwift on a spin bike with speed and cadence sensor for a while and I tend to show about 1.5 to 2x the watts on Zwift as the bike reports on its computer. Would adding a power meter instead of a speed/cadence sensor on a spin bike be more accurate or will it just be way off no matter what because it’s a spin bike? Has anyone had experience with a power meter on a spin bike?
I’ve gotten pretty good at modulating climbs with resistance and have wheel size/selected trainer dialed in as best I can but my watts are still too high. My speed is also too high so my distance is off. I would like to have it dialed in better so I can do cycling challenges and group rides. Would a power meter be more accurate?
Yes, I understand an indoor bike is not compatible with Zwift but I needed something quiet.
Thanks,
Steve
If you can add power meter pedals or a power meter crank (so if your spin bike can take those) then it will likely be a lot more accurate, yes.
You can also check out the open source project SmartSpin2k if you’d like to add smart trainer functionality to your spin bike.
4iiii Fliiiight smart trainer is dead-silent: 4iiii Fliiiight Smart Trainer In-Depth Review | DC Rainmaker
I’d sooner go that route than invest a lot in a spin bike.
