Help friends, I just bought the tacx flux 2 and I have no resistance, no tension when pedaling.
in the intervals does not increase the resistance.
1- use the application from the iphone
2- via bluethooh
3- I do not see the ERG mode to enable or disable
Thanks in advance
what should i do to make it work?
Hi @Jose_Chaves
Did you pair the trainer as power and controllable?
Hi i have had same problem when i first bought tacx flux 1, uninstall and re install app for both zwift adn Tacx - ensure you have bluetooth enabled only with the trainer and not other devices such as music and make sure you are not running at same time the TACX and Zwift app. that should sort you issue
@Gerrie_Delport_ODZ is working now.
I deleted and reinstall apps
Power and controlable is paired now.
Hi @Paul_Ryan2 followed your recommendations and is now working
Thanks man
