Place to see previous attempts on KOM/Sprint Segments
It would be nice if there was a place to look at previous KOM/Sprint segment attempts. I know I can look in Strava, but all the KOMs/Sprints in Zwift aren’t set up as Strava segments. I can follow my 90 day pr on the course, but I’d like to be able to see previous attempts in a chart to view progress.
You can do that in the Companion app. Choose a route that has the particular segment on it and you’ll see your lifetime stats for that segment.
I know this is an older post but where in the companion app can you see past history of a particular KOM/segment? I see my recent results but nothing prior?
If you choose a route in the companion app, then select one of the segments it will show quarterly results, if there’s more than one result for a quarter you can select and it’ll breakdown into the fastest daily result.
This does not seem to work for event routes. Either that or it is bugged as I just did Tropic Rush in Mkuri Islands and I have screenshots of my results on the Tower Sprint at the end but can’t see it in the route page.
If you find another route that has Tower Sprint in ot your data will be there
Yes it does not work. To find your historical times on Tower Sprint you can use the Routes page in Companion and look up any of the routes mentioned here:
