Pace Partners on TT bikes
Yumi is on the Pinarello halo TT bike right now and this morning was the best pace partner experience in my entire time on Zwift. I’ve long suggested putting the PPs on TT bikes to keep a steadier pace (and it needs to be a TT bike for the better CdA, as we all know how it went when they just turned off draft for the bots but kept them on regular trons) and it was great to actually see it in practice. Good steady pace with zero surging due to group behavior, my average power over 70 minutes was within a watt of 2.9wkg (at 77.8kg for me today) which is the advertised effort for Yumi.
Given that the pace partners on halo bikes thing probably won’t last forever, the best way to permanently implement this would be to either stick them all on existing TT bikes, or to create a custom “tron trial” bike only for the bots with all the stats and characteristics of a TT bike (improved CdA, provides draft to others, but gets no draft benefits).
This was the single biggest improvement to the pace partner experience I’ve seen in my time here. Not sure if @shooj or @James_Zwift are the right people for implementing this but I’m sure one of you know who to talk to.
Put the robopacer on the Cadex or give the tron some aero bars. And TT behaviour and that will be another TT bike available for everyone too.
While I don’t recall them being on TT bikes, Zwift tried this some years ago.
It was rapidly reversed, so I’d be surprised if they went there again.
I don’t think you read my post. If you had, you’d have seen the sentence regarding that incident.
So once again, I’m not saying they need to just turn off draft for the pace partners. Putting them on a TT bike, like Yumi (and I assume some other bots) is on right now, results in approximately the same pace as before, but without the random surges caused by user behavior. This is because TT bikes have better CdA numbers than road bikes (like the standard Tron, which is what happened in the incident I refer to in my initial post) and as a result go faster.
This is exactly why it should remain this way.
Zwift accidentally testing something that users have been suggesting for years with well thought out reasoning, and it turns out to be a resounding success. Brilliant.
Are you sure it’s accidentally?
Someone I know checked on Sauce and found that draft was enabled for Yumi. Can you double check?
Yes Robopacers have draft and they are not using TT Bikes but the new HALO Bikes :zany_face:
I think @calfzilla is experiencing that Robopacers are a little faster because on a faster bike and PD5 acts better in this case because most of the riders in a group are holding the power of Yumi and not putting out more power as is the case with Coco and slower RB…they ussualy get much bigger group and most are pushing above RB power and that’s why it feels harder to move in the group.
Yumi group can be fast as well at times - same as Jacques group sometimes races Genie group.
So I guess we ask again, please try robopacers on TT bikes. :slight_smile:
Smoothest pace is Big Mig - apart from little old people doing 7.0w/kg for hours (with warning triangle), nobody else can get ahead. :wink:
Yumi is using the Pinarello Halo bike, which is a TT bike. Same bike that Big Mig is on.
Is there any way to verify whether they’ve set this particular pacer is getting a draft?
People were checking this using Sauce.
/puts tongue in cheek/ Just going to say, called it a while back :wink:
The day before it only took 2.35wkg to sit with coco, who I believe was on the specialized halo bike, which is not a TT and so would be slower just like before.
But I was regularly sitting out a few m in front of Yumi without the bot picking up extra speed.
I did read it, but I didn’t appreciate the detail. Sorry =)
Yes multiple of us saw that Connie, who is now on the pinarello halo TT, was getting draft. Other users in the pack who were on TT were not getting draft as expected however something seems hard-coded in the pacers that they are able to get draft. The downside is that being on a TT it means the pacers can be pulled even more than before. Connie has been a bit barren last week at the times I normally ride as it’s been much tougher than usual when someone is out front pulling. I’m not sure if this is intended by zwift or not.
I know ZHQ feel they have tried that experiment and it didn’t work but, that was back in the old days of just 4 pacers and different weights.
I wish the names would still start with the same letter as the power category of the pacer.
A -B-C- D.
I’m not a fan of the random names.
And the Constance pacer bot yesterday was absolutely flying everywhere. The surging was awful.
With the pack dynamics anyone coming from behind pushed me out of draft. :frowning: They should be having to go around me instead. Then when I get shoved to the side I get no draft and have to do huge power.
