So Zwift I have done two classics as a cat D and now suddenly after watching the Richmond race there is no D race. Why is this?
If you look carefully you will notice that A, B and C cats are each different distances and each cat is open to anyone (1-5w/kg). Although the C cat still shows 2.5-3.1w/kg but I think that’s a typo.
Why did Zwift change from w/kg cats to three separate distance events? Why does the women’s event still use the w/kg cats? If I know the answer to these questions I could probably predict next weeks lottery numbers.
Good spot thanks however why change the format once the series has started. I will enter then based upon laps not w/kg cat
