I would like to know if people lower the trainer difficulty for racing. I always ride at a 100%. I was wondering though if it would be easier on the legs to pace certain wattage without the feeling of “intervals” due to the inclines. I know that you always have to push the same watts. What do you guys think?
From what I’ve seen on any given segment lowering the trainer difficulty makes it easier to spin but you don’t go as fast. To do the segment you need to use the same amount of energy overall.
% difficultly, harder to pedal but you move faster.
Lower difficulty, easier to pedal but you move slower.
David
What i heard some people who are racing lower their trainer difficulty enough so they can keep their chain bigger chainring. Probably means better response for speed change and less gear change. Most of time i keep my trainer difficulty a 100% but when i ride to Alpe du Zwift or any other steeper climbs i lower to 75% to have more lower gears to use if needed.
I have 2 gear setups for my road bike. For flats (home roads) and for mountains (vacations). If current setup is mountain, 11-36 cassette and compact crankset i use 100%. For flat setup i decrease it to 75-80%. Prefer hilly races.
From what I’ve read, most of the top end Zwift racers lower trainer difficulty significantly. It minimises gear changes for one thing. I recall hearing some race as low as around 20%.
It doesn’t matter what difficulty you have the trainer set to with respect to how many watts you have to put out to climb a given hill in the same amount of time. Racers generally set difficulty anywhere from 0 to 30% I have heard (your mileage may vary) in order to minimize gear changes so that you don’t get dropped spinning out when the incline disappears. Some people like to feel the full incline of hills when just puttering around but it has no impact on how quick you are at a given wattage. Think of it as a gearing modifier that is especially useful if your bike only has a 11-25 cassette on it and you want to climb the Alp de Zwift and aren’t a professional.
Thanks for your answers. I am well aware that you still have to put out the same amount of watts. Personally I am struggling sometimes to keep to watts up for example a climb flattens out a little or I am loosing for the first part of a slight downhill. I thought maybe this wouldn’t be as bad on a lower trainer difficulty. Of course I am going to test it out. I was just wondering about people’s experiences.
40% for me. Racing Volcano flat I pretty much don’t have to change gears. I just get up out of the saddle on the couple of small hills.
I did the TTR volcano flat race - 5km this morning on 100% just to see what it’s like…never again, even though my power was a little higher than usual.
Yes, most racers probably set it to about 20-25% from what I have heard. I keeps your effort more consistent overall, but it also allows you to push much more on downhills when you otherwise might spin out too much. I usually ride at 40-50% so I can keep it in the big ring and don’t have to shift as much.
If you ride with a dumb trainer but a pedal or crank mounted power meter then you can quite easily go through a whole race with hardly any gear changes. In a TT for example you can just put the chain in whichever gear gives you a comfortable cadence for the power level you’d want to achieve and just pedal away without worrying about gradient changes.
This is something that should be fixed in races, e.g. set to 75% with no option of changing.
Everything that gives an advantage / disadvantage should be off the table when it comes to racing. If you don’t like hills do a flat race.
Trainer difficulty does not make it harder or easier. It just change how you use your gears. Same difference as people running 56-11 vs 46-13.
Some get there power from high revs others form torque.
I get it from change in resistance. For that reason I very much like the Alpe du Zwift since it is quite irregular.
This is true - to a point. But I’m sure at some level there is going to be a difference in the dynamics. The difference between 0 and 100% reality is going to be more than just choosing gearing I’d have thought.
It’s literally just gearing. Difficulty is not an accurate title for that setting
Not necessarily true.
Sure you have to put out the watts to get the speed. However, I agree with the augment that if everyone is on 100%, we all then have to grind up the hill whether you like it or not.
Some people don’t do well at a cadence of 40/50 and at this cadence we all have to get out of the saddle on some climbs, this uses more effort. This is how it is in the real world, I don’t see why it should be different in the game.
Personally I ride an 11/32 in the real world, so I do the same on zwift. It gives me full range, but as an 81kg rider I still have to get up out of the saddle sometimes. I set my difficulty to 100%.
It would be interesting to see what the simulated gear ratios are for an 11/28 when you toggle the trainer difficulty.
So its not really the same. If you are not so strong (physically) and you hit a 10/15% and your cadence is killed to 50rpm it makes it much more difficult to get the power (output) up because they don’t have the physical torque to get the rpms up.
Lets face it, people are making the adjustment because it’s easier.
That’s what gearing is, it makes things easier…
There’s a reason we aren’t riding single speed bikes anymore
You aren’t a lesser rider with a 32 tooth vs someone else with a max 25 tooth. No reason to not set up your equipment to work best for you
I’m not going to repeat all that I already said.
People change it because they don’t have climbing bikes on their trainers.
With this I can climb anything in Zwift at 100%
Nobody is asking you to repeat. And whilst your opinion is valid, is not final or fact.
I would imagine most racers are not hooking up a adventure bike with odd ratios. But we can assume all we like what people are doing and why, it does not matter.
Bottom line is everyone is grinding out of the saddle on a longer 10/15% climb at some point in the real world and that’s how it should be in a zwift race. You should not get to choose to time trail it.
Zwift may be offering the toggle to please everyone with odd ratios, but this is not the point.
