Is there only 1 gravel/offroad route
I tried to find info on this in the forums, but could not find it:
Is there currently only 1 ‘offroad’ route, and is it correct that you can only ride that with the steering
feature enabled ?
Repack Ridge is the MTB course that requires you to have steering enabled. The route is accessible from Titans Grove only. The Jungle circuit is an option that doesn’t require steering, you can find that in the routes on Watopia.
:ride_on:
The jungle circuit is mostly gravel.
There’s something at the top of the alpe, you can briefly see it as you turn back down. Not rideable though.
