I have a question on the saddle height of the Kickr Core 2. I am quite tall (195cm / 76,77”) and have values from a bike fitting that are the following:
Saddle Y (A): 805 mm (31.69”)
Saddleheight (E): 883 mm (34.76”) / Middle of the saddle: 877 mm(34.53)
When comparing to the Zwift Sheet with the bike measurements, the given saddle height is a little to low. Could someone give me an advise if the bike could fit me or if there are possible adjustments to increase the saddle height?
Hi @Eric_Offermann welcome to Zwift forums.
Is your fitter’s measurement taken saddle <> center of the bottom bracket? Or saddle <> center of pedal spindle?
If it’s saddle <> bottom bracket, you may find that Ride’s seatmast may not be long enough.
A ~50 mm difference from your bike is quite a lot.
If it’s saddle <> pedal spindle, the Ride should work.
