Finally checking back in about the kickr climb plus kickr v6. I was able to recreate the extra decline while on the flat and extra incline on the flat while riding double parked at around 38.5 and 40.7km. I snapped a screenshot when the gradient finally started to match the current actual gradient. It was an extra .2km each or so.
Anyone else getting an issue where the 20% seems to only kick in on the trainer half way up the slope, then stays on 20% for a few seconds after?
Neo 2T
Everyone seems to leave me for dead at the top - even more than normal.
Thanks, I’d looked at the bug report section, never thought to look in Known Issue - Doh!
Its all of the NY escalators for me, no problems on the London routes. Saris H2 trainer.
one thing I have noticed on my neo 2T is if i left the escalator take me up without any effort it seems to take quite an effort to get going again once up top on the flat
I tried today, with trainer difficulty 0, then 100%.
I was left for dead each time.
At 9:45 and 23:30
First time I pushed 9+w/kg at the climb, got dropped like a stone by people doing half that.
Second time I came through the pack to hit the ramp at 46km/h, much faster than most and got dropped again.
(I do know that taking some speed in and hitting it hard at the top it optimal, this was an experiment remember).
Wow, that is quite impressive evidence.
On a Saris H3. The bottom of the escalator seems OK but the last 1/3 or so is like hitting a wall. In London, if I hammer it I’m rewarded but in New York, it’s like the harder I work the slower I go - especially near the top. And I’m in the right climbing gear but it’s almost like I can’t pedal at all. If I take it easy, I make it to the top without destroying my legs but I’m dropped by everyone else who were going roughly the same wkg or even less.
Ok I have a theory for that. I’m riding using ThinkRider XX Pro which is as Tacx Neo2T direct drive trainer without flywheel. I think we are in trouble because our trainers change the power from 0% gradient to 19% instantly, when guys on flywheel trainers have some momentum for almost the whole hill. They get what we have at the end of the climb when their flywheel finally stops boosting them.
For me it’s like hitting a wall, I’m dropping my large cog to small one and cassette to 32t and I can’t keep any reasonable cadence. At the end everyone fly through me because I need to go back to large cog and progress through cassette
I am riding Neo and have no problems - hitting the escalator with 30-33 km/h, no power needed, about 25 km/h speed up - I have to start pedaling again (hard) before coming to the top (don’t ask when exactly - it is not always the same, group rides different to free rides).
I tried keeping a steady pace between 4 and 5 WKG and I kept it going after coming off the escalator and was not dropped, another time I just kept the pace I was doing on the flat with 4 or 5 others as we were dropped anyway and I overtook a rider on the escalator doing double my WKG, the escalators like the steering don’t really add anything to my experience except mild annoyance and no idea what the power section is about or where it even is as I have never appeared on the leaderboard, it just keeps popping up on the screen in the subway.
I wonder what you both have trainer difficulty set at?
I have default - 50%
U noticed the same like me.
Im on the Kickr Core, with 100% TD.
Absolutely do not enjoy the NYC escalators. So steep I can’t even pedal it. So I get hauled up, then get bogged down at the top and have to build back to my cadence. Breaks my rhythm and adds no value to my experience. I’d rather have these as a 7% switchback grade up a ramp.
I can pedal up the London “escalator” ramps with effort, that’s fine. These ones in NYC act different, and not in a fun way.
I think they’re ridiculous, and hence they’re kinda fun and different. At least everyone goes through them and experiences whatever they experience. Kinda like an Act of God unknown variable thrown into whatever event uses one of these courses.
I’m on kickr core 2. I did the nyc stay puft today. First time up, with group, about 40kph, doing 600-700 watts. Took about 7 secs
2nd time up, I was solo. Popped a feather, going about 38 kph, soft pedaling about 1.8 wkg and made it up in….7 secs.
maybe we are not supposed to hammer them going up?
Using an Elite Direto at 100%. After the escalator, the trainer is stuck at 19% for no less than 5 minutes. And it keeps on emitting strange noises. Then slowly it goes back to normal, until the next escalator. Please fix this. I’ve found out that if I put on the lowest gear I have just before the escalator, and then do not touch the pedals at all while going up, all is good. Still, please fix it
They do need to improve the escalators, but even so what you are experiencing is not normal. Resistance should drop shortly after you reach the top of the escalator. I wonder if your trainer needs the motor screw cleaned and lubricated (ie, mechanical problem when you get to maximum resistance). If it is not a new trainer, that is a task that may need to be done periodically.
