Everyone please note. Update at your earliest convenience.
Thank you for fixing this!!!
It shouldnât show up if you ride a time trial frame.
Seems this happens when the event is not scored, but the result screen is still set to show scores.
Itâd be a similar issue to what happens if youâre the only one to finish the race.
And the opposite happens too - races which are scored but the results donât show the scores.
Finish line crash 2 of 2 from the update. Custom distance event. I had my squirrel out.
Why do I get a drop box (practically full screen) that ask me to choose between 2 challenges ( Everest - California) before start of every NEW ACTIVITY on initial boot of game, of which i completed many years ago. I click ok and it goes away so I can begin the ride kinda irritating as it started 3 or 4 weeks ago?
I run Windows and android companion on Wahoo CoreâŚthank you
I think the issue is you have to scroll to see there is another new challenge there (The Factory Tour Challenge), once you select that challenge you shouldnât see this again.
Not sure if this was updated while I was out for a couple weeks or this update but my ZP controllers steer much better now. Much more responsive to the steering inputs. Thank you.
Edit: the steering was only more sensitive on the cobbles in France. London was the same as it has been.
ThanksâŚmakes sense and will try âscrolling - sideways or up and downâ next time I log on
In spite of having set my Garmin account settings for allowing data with Zwift, I still do not see any of my outdoor trainings in Zwift Connect. When will this be effective?
It is already active. Have you gone through the process of using the Zwift Companion app to remove the connection to Garmin Connect, and then reconnect?
Try changing to a gravel or MTB bike. Then check.
The new wheelset may be specific to a non-road frame.
Reporting really bad glitching on AppleTV on this cobble section here. Get it riding solo or in an event. Am on latest update. All other cobble sections fine.
Solution has already been given above:
Do you always force-close Zwift after saving your rides? Because lots of weird stuff can happen if you donât.
This is a performance problem with your Apple TV device. If it were happening generally there would be a huge amount of noise about it.
I would say I do it often, but not every single time. Will be more militant from now on!
I think two things:
one, I believe this flyer setting is now turned off for Zwift official elite races (because I have seen four or five people go in excess of permitted w/kg.) These are considered âpro levelâ races.
two, I saw someone doing about 9 w/kg for a minute, maybe less. But, when you use a feather power up, your weight is reduced by 10%. Thus, a rider of 70 kg is riding at 63 kg during that minute that got auto detected and flagged.
Zwift has never officially revealed the numbers they use to discover âproâ watt levels.
My coffee break option stop working ![]()
Hell of the North not updating after rides tried
3 times
No extras XP given
