In that situation I would upload a log file to zwiftalizer.com and check for anything weird going on. That option is not available if you use Apple TV but all other platforms can do it.
Canāt quit event. Button pops up but then slides back down below view. Only menu button is visible and clickable.
iPad Pro 9.7 inch
OS 16.7.10
Donāt know if this helps, I use PC and windows.
If I run Zwift as windowed and drag the edge to resize the window, it takes care of similar issues.
Unfortunately, this is not saved and I have to do every time.
Kph instead of km/h would fit better and may be more common usage
Double wrong! We waited for years to get the correct SI unit for speed.
By the way, in the new HUD there is no SI unit for average power. Why not use Ć169W?
And why are there two different Power icons in that same section?
Just saw a black square in the jungle riding by myself, road to sky route and it happened where the 10 year confetti is going. 1.74.2, windows. Daytime
Edit: and a whole bunch more leaving the alpe area approaching the force field. Night time
It seems that after this update some of the before saved settings were set to default values such as navigating on crossroads with buttons on handlebars. I have switched it off some month ago and it was off. Yesterday I was riding Radio Rendezvous route and on the last crossing I pressed a button and navigated off the route⦠very frustrating at the end of such a route. Then I saw in options that this setting was on.
I use Windows Borderless Gaming to automatically do that job, because my computer has something that always seems to grab attention from fullscreen Zwift.
The only issue Iāve have with WBG is that sometimes I have to click slightly higher on the screen than the buttons appearālike the functional button area is just a little offset from where it appears. But thatās not a problem at all.
Mine matched Zwift Insiderās information on an event:
It looks like yours starts after the lead-in.
Iām amused by the Shisa vs Shisha terms in the game for this route.
Zwift Insider calls it Shisa Shakedown and ZwiftApp calls it Shisha Shakedown. Which is it supposed to be?
I appreciate the reference since Shisa Shakedown is in Yakuza 3.
It should be Shisa, because thatās the name for the temple guardian statues that are on the route. Shisha is something else entirely.
Shisa is correct. The banner should be corrected in game with an upcoming release.
Itās also wrong in Companion and on the badge name in the ZwiftApp list.
Not related to the app version, inside and outside of a group ride tonight we were having difficulty sending chats. Using Send Group Text or Companion would show the text in Companion but not in ZwiftApp. About 1/7 messages went through. It was happening around 18:00 Pacific until at least 20:00 for us. It would sometimes work better for a bit and then start giving us trouble again. A few of us used Discord instead.
i would not be surprised if that was still the reference, depending on who did the naming. haha
Just had that issue today with update 1.76 on my iPad during the TOW on the mountain route. At almost the exact same spot. Seemed like it was where the butterflies were flying. Did not have that issue before when riding that part of the course. And later on it also did not happen again. Only that section of the route seemed to have that issue.
