Game Update v 1.123 [October 2026]
Hi Zwifters,
Phased rollout of game version 1.123 begins today to macOS / Windows / Android devices.
Phased rollout to iOS / tvOS begins tomorrow.
All Platforms
New Bikes are rolling into the Zwift Drop Shop from the Kona Ironman World Championship! Zwifters can find the following new bikes in the Drop Shop under each respective brand’s collection.
  • Factor Hanzō TT (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 42 and 1,800,000 Drops.
  • Cervelo P5 (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 39 and 1,600,000 Drops.
  • Cannondale SuperSlice LAB71 (Aero: :star::star::star::star:, Weight: :star:) - equires Level 40 and 1,500,000 Drops.
  • Quintana Roo V-PRi (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 41 and 1,450,000 Drops.
  • Cube Aerium C:68X - Lucy Charles-Barclay Edition (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 38 and 1,400,000 Drops.
  • Giant Trinity Advanced SL (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 37 and 1,300,000 Drops.
  • Liv Avow Advanced SL (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 37 and 1,300,000 Drops.
New Time Trial Wheels rolling into the Zwift Drop Shop from Reserve, Cadex, and all new Black.Inc!
  • Reserve Infinity Disc TT Wheelset (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 42 and 1,100,000 Drops.
  • Cadex 4-Spoke/Disc TT Wheelset (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 41 and 1,000,000 Drops.
  • Black.Inc THREE/ZERO TT Wheelset (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 40 and 950,000 Drops.
We will be removing the following Bikes from the Drop Shop:
  • 2015 Cervelo P5 (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 15 and 920,700 Drops.
  • 2015 Pinarello Bolide - (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 25 and 618,400 Drops.
  • 2019 Cube Aerium (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 28 and 251,700 Drops
  • 2022 Quintana Roo V-PR (Aero: :star::star::star::star:, Weight: :star:) - Requires Level 16 and 638,600 Drops
Fixed an issue that could potentially cause activity FIT files to be missing or corrupted.
The Progress Card now shows the correct sport level after switching between running and cycling.
Your profile icon in the top right will no longer show level progress as the Progress Widget takes over that role.
Note: We’re currently running a test that will help inform us on future changes to our routes page. The test should conclude by October 21.
Android
On Android 12 and newer, Bluetooth devices can now be scanned without granting location permission or enabling Location Services.
iOS, tvOS, macOS
Improved Bluetooth connection reliability.
UPDATED October 8
Belated release note
  • M6 Macs support Ultra graphics profile
UPDATE October 8
Phased rollout is complete to all OS platforms.
Do you have questions or issues to report? Let us know below.
Could you also specify what Tier the frames are ? Since it is impossible to see what tier they are before we buy them it is kinda handy info to have.
Just a Entry, Mid or High tier mention on the frames would do.
And there is a new route badge in the update :
Sacré Trois!
Eric says a few of the older TT frames are “updated.” What does that mean exactly?
@Peter_Twigt your request has been noted.
In the meantime, you can consult GameDictionary.xml (bikeClass in BIKEFRAMES).
Why do we have to go to some guy’s blog to get complete update release notes?
The XP progress donut around my avatar picture doesn’t show up. I’m over 15% to the next level, so there should be some part of that donut showing.
This was removed because the widget right below has the same info now, its just in a new spot.
It makes sense. I didn’t see that mentioned in release notes.
That’s disappointing, I liked the orange ring filling in. With no progress in that spot it would look better as orange than gray imo
Or just remove it and make the profile pic larger.
The problem is for running.
Running doesn’t get the widget, yet the donut ring is gone.
From a 1.122 Zwift -
From a 1.123 Zwift -
Running doesn’t get any progress indication now.
Is there an easy way to view this ? I dont mind checking this myself after each update but now it ;ooks like this
Ohh nevermind. Gemini does a pretty good job at that.
Here they are :
High End Factor Factor Hanzo
High End Cervelo Cervelo P5
High End Cannondale Cannondale SuperSlice LAB71
High End QuintanaRoo QuintanaRoo Roo V-PR
High End Cube Cube Aerium
High End Giant Giant Trinity Advanced SL
High End Liv Liv Avow Advanced SL
What’s that? Riding this frame you get a drop multiplier like riding with a BOT? is that available on other frames as well? Road or just TT?
Entry level bike gives 5% extra drops at stage 4 and also 5% extra XP at stage 5.
Mid Range bike gives 5% extra drops at stage 5.
Thanks for the reminder Ian. When I read Peter’s post, I was thinking about frames without stage upgrades, must have been lack of morning coffee :wink: got that fix now :teacup_without_handle:
The surrounding riders hated that
Also just another reminder to the ZHQ team to move to 5 stars.
Literally everything is the same rating. Has there been anything released this year that isn’t 4 stars? (If there was, I’ve forgotten).
Alternatively… keep the 4 stars if it’s impossible to go to 5, and make the system logarithmic at the end.
This is made massively worse by the removal of older, slower frames from the system; meaning now I think literally every TT bike in the drop shop has 3 or 4 stars for aero which negates the entire purpose of the rating system entirely.
I will also even call it confusing that the P5 is a mid-level frame, but it is in the mix with all other frames, and has the same rating.
Make it make sense.
