I sure agree with you on that draft remark: “… I wonder when a more realistic ride feel with more perceived and noticed draft”
These big pacing groups are pretty weird to ride in. I mean, the pace that they advertise cannot be the real pace due to draft that you would have on the real road. But then again you do not feel an increase or decrease if you change positions through the group from front to middle or other way around.
From what i feel and watch on Sauce there is clearly a difference from being in the middle or at the back but you need to find the perfect position.Most of the people go front back to the front and then straight to the back over and over because there isnt any collision apart from the front row
Having an issue where the power in the HUD reads 0w. However my avatar moves and the power is displayed in my companion app. However, I changed the power from 3 second average to instant last night and it started to work. If I go back to 3 second average the power again reads 0w.
Went to ride this AM and found that the virtual shifting was not present in-game. I could connect to the click shift on the connections page but nothing was showing up while riding in game, so I was stuck in a single gear.
Restarted the computer, and went back on, same thing. Particularly troublesome when the Zwift Hub One Cog has only one gear lol.
On your iPad, go to the App Store and find the Zwift app in the list of your apps. If you tap on it should show a version number on the information page under What’s New. Also if it is up to date you will have an Open button to open the app. If there is a pending update, then the button will say Update instead.
*Steve, will give that a try this afternoon. Thanks! I had been using ANT+, yes. Virtual shifting was connected via BT. I’m not sure why the trainer would have chosen to connect via ANT+ instead of BT
I like it too (group rides and cruising freely on Watopia) but too many things could be way better. At the moment folowing the 6 week FTP builder plan but find that you dont get a basic calendar with it … already planning to start a 12 week MTB plan on Systm after this, where at least I have a calendar and can mover workouts around and see the hole “picture”.
Clicking on the balloon for riders I follow, and it was showing the ride on as filled. I clicked on the three dots, and back, and the ride on wasn’t used. So I clicked the thumb, and all was good, but on other riders I got the screen as if they weren’t riding, and yet it would change again if I clicked off them and back on.
Also followed riders would often show up on the small window map in the upper right, but not show on the actual main map.
And the riderboard was zipping from the bottom to the top a few times as well.
Was there a Companion update? I checked before riding and it was only the iOS Zwift app.
When will the distance indication from the back end be supported on the ipad? It has been causing inconvenience to this problem for years, so why not solve it? I doubt you are willing to solve it. If it’s a problem that can’t be solved, please explain why it can’t be solved.
34, expecting to accelerate to ~60. I have uninstalled the android app and the MacOS to see if reinstalling them solves the issue. It hasn’t helped in android but I am yet to check my Mac.
You should definitely be on the 20% discount but I don’t think you’d get the double xp. So you should see the double chevrons and the level you are discounted too.
Here are 2 attachments to show that I am on version 1.54 and that I’m not doing a wheelie and have nothing showing the level I’m accelerating to with the 2 chevrons.
To add further detail to this, this is the same on android (Google pixel) and on MacOS.
