Hi - getting crashes several minutes into ride - no obvious catalysts as just riding along not doing anything with the computer
there is the crash report
Process: ZwiftApp [1500]
Path: /Users/USER/Library/Application Support/Zwift/ZwiftApp
Identifier: ZwiftApp
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: ZwiftApp [1500]
User ID: 501
Date/Time: 2016-12-17 07:07:22.435 +0000
OS Version: Mac OS X 10.10.5 (14F27)
Report Version: 11
Anonymous UUID: 1BE1BE78-04B3-E5E2-45CA-07E6DA912976
Time Awake Since Boot: 1400 seconds
Crashed Thread: 13
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000010
VM Regions Near 0x10:
__TEXT 0000000101b09000-00000001022f0000 [8092K] r-x/rwx SM=COW /Users/USER/Library/Application Support/Zwift/*
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fff96454136 __psynch_cvwait + 10
1 libant.dylib 0x00000001029ca969 DSIThread_CondTimedWait + 156
2 libant.dylib 0x00000001029c03bd ANT_Close + 89
3 ZwiftApp 0x0000000101b3a1fa ANT_DeviceSearch(ANT_SEARCH_MODE) + 426
4 ZwiftApp 0x0000000101b3fc20 UI_PairingScreen::Update(float) + 1120
5 ZwiftApp 0x0000000101ff3c8e GUI_Update(float) + 174
6 ZwiftApp 0x0000000101c05252 UI_Update(float) + 18
7 ZwiftApp 0x0000000101c7b88c Render(float) + 5356
8 ZwiftApp 0x0000000101c7bd94 doFrame() + 804
9 ZwiftApp 0x0000000101c89ea5 CODEmain(int, char const**) + 85
10 ZwiftApp 0x0000000101c5aa63 main + 595
11 ZwiftApp 0x0000000101b0ab34 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff96455232 kevent64 + 10
1 libdispatch.dylib 0x00007fff9c1a6a6a _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff9645448a __semwait_signal + 10
1 ZwiftApp 0x000000010200b263 JM_Worker_Thread(void*) + 307
2 libsystem_pthread.dylib 0x00007fff951d705a _pthread_body + 131
3 libsystem_pthread.dylib 0x00007fff951d6fd7 _pthread_start + 176
4 libsystem_pthread.dylib 0x00007fff951d43ed thread_start + 13
Thread 3:
1 ZwiftApp 0x00000001020c0eab AK::StreamMgr::CAkIOThread::IOSchedThread(void*) + 75
Thread 4:
0 libsystem_kernel.dylib 0x00007fff9644f51a semaphore_wait_trap + 10
1 ZwiftApp 0x0000000102095df3 CAkThreadedBankMgr::BankThreadFunc(void*) + 51
Thread 5:
1 ZwiftApp 0x000000010209a79f CAkAudioThread::EventMgrThreadFunc(void*) + 63
Thread 6:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff9644f4de mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff9644e64f mach_msg + 55
2 com.apple.audio.CoreAudio 0x00007fff967ba57e HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3 com.apple.audio.CoreAudio 0x00007fff967ba50c HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fff967b8aa9 HALC_ProxyIOContext::IOWorkLoop() + 965
5 com.apple.audio.CoreAudio 0x00007fff967b8612 HALC_ProxyIOContext::IOThreadEntry(void*) + 88
6 com.apple.audio.CoreAudio 0x00007fff967b84e3 HALB_IOThread::Entry(void*) + 157
7 libsystem_pthread.dylib 0x00007fff951d705a _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff951d6fd7 _pthread_start + 176
9 libsystem_pthread.dylib 0x00007fff951d43ed thread_start + 13
Thread 7:
2 com.apple.CoreFoundation 0x00007fff96117eb4 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff9611737b __CFRunLoopRun + 1371
4 com.apple.CoreFoundation 0x00007fff96116bd8 CFRunLoopRunSpecific + 296
5 com.apple.AppKit 0x00007fff8e80a56b _NSEventThread + 137
6 libsystem_pthread.dylib 0x00007fff951d705a _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff951d6fd7 _pthread_start + 176
8 libsystem_pthread.dylib 0x00007fff951d43ed thread_start + 13
Thread 8:
0 ZwiftApp 0x0000000101e11f7c zwift_network::UDPClient::reconnection_handler(std::__1::shared_ptr<zwift_network::UDPClient>, bool) + 246
1 ZwiftApp 0x0000000101e13202 asio::detail::completion_handler<zwift_network::UDPClient::reconnection_handler(std::__1::shared_ptr<zwift_network::UDPClient>, bool)::$_0>::do_complete(asio::detail::task_io_service*, asio::detail::task_io_service_operation*, std::__1::error_code const&, unsigned long) + 244
2 ZwiftApp 0x0000000101ea567a asio::detail::task_io_service::do_run_one(asio::detail::scoped_lock<asio::detail::posix_mutex>&, asio::detail::task_io_service_thread_info&, std::__1::error_code const&) + 560
3 ZwiftApp 0x0000000101ea523e asio::detail::task_io_service::run(std::__1::error_code&) + 416
4 ZwiftApp 0x0000000101e15597 asio::io_service::run() + 43
5 ZwiftApp 0x0000000101ea9cfc asio_detail_posix_thread_function + 19
Thread 9:
5 com.apple.CoreFoundation 0x00007fff961ce671 CFRunLoopRun + 97
6 libant.dylib 0x00000001029c5641 IOKitDeviceHandle::EventThread() + 265
7 libant.dylib 0x00000001029c47b3 IOKitDeviceHandle::EventThreadStart(void*) + 9
8 libsystem_pthread.dylib 0x00007fff951d705a _pthread_body + 131
9 libsystem_pthread.dylib 0x00007fff951d6fd7 _pthread_start + 176
10 libsystem_pthread.dylib 0x00007fff951d43ed thread_start + 13
Thread 10:
0 libsystem_kernel.dylib 0x00007fff964555c2 poll + 10
1 libant.dylib 0x00000001029c545e IOKitDeviceHandle::SendSyncBulkTransfer(unsigned char, unsigned char*, int, unsigned int, int&) + 182
2 libant.dylib 0x00000001029c6080 USBDeviceHandleIOKit::ReceiveThread() + 178
3 libant.dylib 0x00000001029c5ed7 USBDeviceHandleIOKit::ProcessThread(void*) + 9
4 libsystem_pthread.dylib 0x00007fff951d705a _pthread_body + 131
5 libsystem_pthread.dylib 0x00007fff951d6fd7 _pthread_start + 176
6 libsystem_pthread.dylib 0x00007fff951d43ed thread_start + 13
Thread 11:
1 libant.dylib 0x00000001029ca955 DSIThread_CondTimedWait + 136
2 libant.dylib 0x00000001029c8122 TSQueue<char, std::deque<char, std::allocator<char> > >::PopArray(char*, unsigned int, unsigned int) + 74
3 libant.dylib 0x00000001029c5fb9 USBDeviceHandleIOKit::Read(void*, unsigned int, unsigned int&, unsigned int) + 35
4 libant.dylib 0x00000001029ca656 DSISerialGeneric::ReceiveThread() + 96
5 libant.dylib 0x00000001029ca4e1 DSISerialGeneric::ProcessThread(void*) + 9
Thread 12:
0 libsystem_kernel.dylib 0x00007fff96454166 __psynch_mutexwait + 10
1 ZwiftApp 0x0000000101b383e3 ANTResponseCallback(unsigned char, unsigned char) + 51
2 libant.dylib 0x00000001029bfe7c MessageThread(void*) + 125
3 libsystem_pthread.dylib 0x00007fff951d705a _pthread_body + 131
4 libsystem_pthread.dylib 0x00007fff951d6fd7 _pthread_start + 176
5 libsystem_pthread.dylib 0x00007fff951d43ed thread_start + 13
Thread 13 Crashed:
0 libsystem_malloc.dylib 0x00007fff8f4e296f tiny_malloc_from_free_list + 327
1 libsystem_malloc.dylib 0x00007fff8f4e17e4 szone_malloc_should_clear + 317
2 libsystem_malloc.dylib 0x00007fff8f4e1667 malloc_zone_malloc + 71
3 libsystem_malloc.dylib 0x00007fff8f4e0187 malloc + 42
4 libc++.1.dylib 0x00007fff9a8e143e operator new(unsigned long) + 30
5 ZwiftApp 0x0000000101eb61d7 std::__1::unique_ptr<std::__1::__tree_node<std::__1::__value_type<Json::Value::CZString, Json::Value>, void*>, std::__1::__tree_node_destructor<std::__1::allocator<std::__1::__tree_node<std::__1::__value_type<Json::Value::CZString, Json::Value>, void*> > > > std::__1::__tree<std::__1::__value_type<Json::Value::CZString, Json::Value>, std::__1::__map_value_compare<Json::Value::CZString, std::__1::__value_type<Json::Value::CZString, Json::Value>, std::__1::less<Json::Value::CZString>, true>, std::__1::allocator<std::__1::__value_type<Json::Value::CZString, Json::Value> > >::__construct_node<std::__1::pair<Json::Value::CZString const, Json::Value>&>(std::__1::pair<Json::Value::CZString const, Json::Value>&&&) + 37
6 ZwiftApp 0x0000000101eb6147 std::__1::__tree_iterator<std::__1::__value_type<Json::Value::CZString, Json::Value>, std::__1::__tree_node<std::__1::__value_type<Json::Value::CZString, Json::Value>, void*>*, long> std::__1::__tree<std::__1::__value_type<Json::Value::CZString, Json::Value>, std::__1::__map_value_compare<Json::Value::CZString, std::__1::__value_type<Json::Value::CZString, Json::Value>, std::__1::less<Json::Value::CZString>, true>, std::__1::allocator<std::__1::__value_type<Json::Value::CZString, Json::Value> > >::__insert_unique<std::__1::pair<Json::Value::CZString const, Json::Value>&>(std::__1::__tree_const_iterator<std::__1::__value_type<Json::Value::CZString, Json::Value>, std::__1::__tree_node<std::__1::__value_type<Json::Value::CZString, Json::Value>, void*>*, long>, std::__1::pair<Json::Value::CZString const, Json::Value>&&&) + 31
7 ZwiftApp 0x0000000101eb2e87 Json::Value::resolveReference(char const*, bool) + 781
8 ZwiftApp 0x0000000101eacb72 Json::Reader::readObject(Json::Reader::Token&) + 674
9 ZwiftApp 0x0000000101eac589 Json::Reader::readValue() + 605
10 ZwiftApp 0x0000000101eac1bf Json::Reader::parse(char const*, char const*, Json::Value&, bool) + 171
11 ZwiftApp 0x0000000101eac300 Json::Reader::parse(std::__1::basic_istream<char, std::__1::char_traits<char> >&, Json::Value&, bool) + 76
12 ZwiftApp 0x0000000101e73e18 std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const> get_accept_json<zwift_network::model::RelayServer>(RequestScopedResources&, std::__1::shared_ptr<RestInvoker>, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::function<std::__1::shared_ptr<zwift_network::model::RelayServer const> const (Json::Value const&)> const&, bool, bool) + 900
13 ZwiftApp 0x0000000101e6c89d std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const> get_accept_json<zwift_network::model::RelayServer>(std::__1::shared_ptr<RestInvoker>, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, std::__1::function<std::__1::shared_ptr<zwift_network::model::RelayServer const> const (Json::Value const&)> const&, bool, bool) + 107
14 ZwiftApp 0x0000000101e6689c RelayServerRestInvoker::get_udp_connection_information(std::__1::shared_ptr<RelayServerRestInvoker> const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) + 510
15 ZwiftApp 0x0000000101e1bc00 boost::_bi::bind_t<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, boost::_mfi::mf2<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, RelayServerRestInvoker, std::__1::shared_ptr<RelayServerRestInvoker> const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&>, boost::_bi::list3<boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > >::operator()() + 50
16 ZwiftApp 0x0000000101e1ba32 std::__1::__async_assoc_state<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, std::__1::__async_func<boost::_bi::bind_t<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, boost::_mfi::mf2<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, RelayServerRestInvoker, std::__1::shared_ptr<RelayServerRestInvoker> const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&>, boost::_bi::list3<boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::__execute() + 30
17 ZwiftApp 0x0000000101e1bcde void* std::__1::__thread_proxy<std::__1::tuple<void (std::__1::__async_assoc_state<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, std::__1::__async_func<boost::_bi::bind_t<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, boost::_mfi::mf2<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, RelayServerRestInvoker, std::__1::shared_ptr<RelayServerRestInvoker> const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&>, boost::_bi::list3<boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >::*)(), std::__1::__async_assoc_state<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, std::__1::__async_func<boost::_bi::bind_t<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, boost::_mfi::mf2<std::__1::shared_ptr<zwift_network::NetworkResponse<zwift_network::model::RelayServer> const>, RelayServerRestInvoker, std::__1::shared_ptr<RelayServerRestInvoker> const&, std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&>, boost::_bi::list3<boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::shared_ptr<RelayServerRestInvoker> >, boost::_bi::value<std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > > > > > >*> >(void*) + 78
18 libsystem_pthread.dylib 0x00007fff951d705a _pthread_body + 131
19 libsystem_pthread.dylib 0x00007fff951d6fd7 _pthread_start + 176
20 libsystem_pthread.dylib 0x00007fff951d43ed thread_start + 13
Thread 14:
2 libant.dylib 0x00000001029c9d0c DSITimer::TimerThread() + 94
3 libant.dylib 0x00000001029c9bcd DSITimer::TimerThreadStart(void*) + 9
Thread 13 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000010 rbx: 0x000000000000000c rcx: 0x7000000000000000 rdx: 0x0000000000000007
rdi: 0x00000000a91a492c rsi: 0x00000000a91a2df6 rbp: 0x000000010318e320 rsp: 0x000000010318e2f0
r8: 0x000000000000006d r9: 0x00007f8c66b15df0 r10: 0x0000000000000033 r11: 0x00007f8c66e91ed0
r12: 0x0000000102a02000 r13: 0x00007f8c69051ca0 r14: 0x0000000000000006 r15: 0x0000000102af9400
rip: 0x00007fff8f4e296f rfl: 0x0000000000010202 cr2: 0x0000000000000010
Logical CPU: 1
Error Code: 0x00000006
Trap Number: 14
Binary Images:
0x101b09000 - 0x1022effe7 +ZwiftApp (???) <684A3E0B-94D2-3DB2-9D2B-1C0D4CD72A4C> /Users/USER/Library/Application Support/Zwift/ZwiftApp
0x10297c000 - 0x1029a3ff7 com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <B355479D-7CBE-3142-80EA-4FD3CCCC56FE> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x1029bf000 - 0x1029dcfff +libant.dylib (0) <69DB8DF7-7E3F-33EE-9472-45DD36CFD413> /Users/USER/Library/Application Support/Zwift/libant.dylib
0x102a09000 - 0x102a4bff7 com.apple.glut (3.6.2 - GLUT-3.6.2) <0BFD84DA-7056-308F-A037-BD18AE13206A> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
0x102abf000 - 0x102ae5ff7 com.apple.audio.OpenAL (1.8 - 1.8) <B05578A8-FE08-310C-BF91-C1BDE10858CD> /System/Library/Frameworks/OpenAL.framework/Versions/A/OpenAL
0x1083c6000 - 0x1083cafff com.apple.audio.AppleHDAHALPlugIn (272.18.1 - 272.18.1) <D6C9695C-4134-35D1-8FAC-8FB6179DFBFF> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x1083cf000 - 0x1085ecff3 com.apple.audio.units.Components (1.12 - 1.12) <AC14ADC7-587F-3E0F-92E7-9D8C07753C22> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x10bd13000 - 0x10bf88ff7 com.apple.ATIRadeonX2000GLDriver (10.0.35 - 10.0.0) <FAE65F98-CCA8-3C77-A0AF-D59D65B5A76B> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
0x10bfec000 - 0x10bff9fff libGPUSupport.dylib (11.1.2) <38FDFC04-055F-32A3-B5C5-B3A624D2543C> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport.dylib
0x145a76000 - 0x145a76fff +cl_kernels (???) <80CC1975-657D-4333-A48C-00EB70974857> cl_kernels
0x145a85000 - 0x145a85ff5 +cl_kernels (???) <2E97D13B-4301-453A-B93E-800E2BF0ABB1> cl_kernels
0x145a87000 - 0x145b6dfef unorm8_bgra.dylib (2.4.5) <5F488C7E-2FB2-3C66-9764-28CF16B03E7A> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x146286000 - 0x14628eff7 com.apple.iokit.IOUSBLib (705.4.0 - 705.4.0) <64EAAA11-3ECD-375A-A589-A2A5C2F21439> /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib
0x7fff6c5ca000 - 0x7fff6c600887 dyld (353.2.3) <B1B370A5-479F-3533-8AD7-97B687D4F989> /usr/lib/dyld
0x7fff8d25a000 - 0x7fff8d2eefff com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8d2ef000 - 0x7fff8d391fff com.apple.Bluetooth (4.3.6 - 4.3.6f3) <E5DC1699-2727-329C-A843-C80CE9A6CD7B> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff8d4b1000 - 0x7fff8d4b3fff libquarantine.dylib (76.20.1) <7AF90041-2768-378A-925A-D83161863642> /usr/lib/system/libquarantine.dylib
0x7fff8d4b4000 - 0x7fff8d538fff com.apple.PerformanceAnalysis (1.0 - 1) <4E934EE0-5CC6-3D54-8FA2-5B8AE669D775> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8d539000 - 0x7fff8d541ff3 com.apple.CoreServices.FSEvents (1210.20.1 - 1210.20.1) <84F79D3E-7B5E-3C93-8479-35794A3F125E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff8d544000 - 0x7fff8d674fff com.apple.UIFoundation (1.0 - 1) <466BDFA8-0B9F-3AB0-989D-F9779422926A> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff8d675000 - 0x7fff8d67dfff libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
0x7fff8d6bd000 - 0x7fff8d72effb com.apple.ApplicationServices.ATS (360 - 375.4) <A1BEBCF8-8FC8-345D-B91D-1DA5773AF5A3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8d72f000 - 0x7fff8d853ff7 com.apple.LaunchServices (644.56 - 644.56) <20AABB1C-9319-3E4D-A024-51B0DD5FCD3B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8d854000 - 0x7fff8d862ff7 com.apple.opengl (11.1.2 - 11.1.2) <5F355713-4637-33CD-9CBA-4B4CA43FB0FE> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff8dd79000 - 0x7fff8dd7afff liblangid.dylib (117) <B54A4AA0-2E53-3671-90F5-AFF711C0EB9E> /usr/lib/liblangid.dylib
0x7fff8dd90000 - 0x7fff8ddc2ff3 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <C6DB0A07-F8E4-3837-BCA9-225F460EDA81> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fff8ddcf000 - 0x7fff8ddd1fff libCVMSPluginSupport.dylib (11.1.2) <1C5C1757-67F1-3C23-90EF-643619A0E7DC> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8dde1000 - 0x7fff8de22fff libGLU.dylib (11.1.2) <2BA52A8D-ED35-3D86-B2D6-41479969C96D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff8de23000 - 0x7fff8de23fff com.apple.CoreServices (62 - 62) <C69DA8A7-B536-34BF-A93F-1C170E2C6D58> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8de33000 - 0x7fff8de82ff7 com.apple.opencl (2.4.2 - 2.4.2) <EB365E68-9965-3596-A40A-D1E372F3A9B3> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8dea0000 - 0x7fff8dea1ff7 com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff8e0a1000 - 0x7fff8e0aeff7 libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
0x7fff8e0b9000 - 0x7fff8e0ccff7 com.apple.CoreBluetooth (1.0 - 1) <8D7BA9BA-EB36-307A-9119-0B3D9732C953> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff8e55d000 - 0x7fff8e66cff3 com.apple.desktopservices (1.9.3 - 1.9.3) <FEE11342-5BC4-37A7-8169-DA48BE17B9C9> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff8e66d000 - 0x7fff8e677ff7 com.apple.NetAuth (5.2 - 5.2) <2BBD749A-8E18-35B8-8E48-A90347C1CCA7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8e6a1000 - 0x7fff8e6b0fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff8e6b1000 - 0x7fff8f232ff7 com.apple.AppKit (6.9 - 1348.17) <E485D56D-3E72-34B7-99BB-BFDEE2D07BF5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8f243000 - 0x7fff8f276fff com.apple.MediaKit (16 - 757.2) <2912E5C2-085F-3FE2-8531-23B6E894B0F0> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff8f36a000 - 0x7fff8f392fff libxpc.dylib (559.40.1) <5C829202-962E-3744-8B50-00D38CC88E84> /usr/lib/system/libxpc.dylib
0x7fff8f3a9000 - 0x7fff8f3b6ff3 com.apple.ProtocolBuffer (1 - 228.0.1) <3429EB06-9F0E-355F-B9AB-F72879177398> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff8f3b7000 - 0x7fff8f3d7fff com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff8f3d8000 - 0x7fff8f4caff7 libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
0x7fff8f4cb000 - 0x7fff8f4dcfff libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
0x7fff8f4dd000 - 0x7fff8f4defff libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff8f4df000 - 0x7fff8f4fbff7 libsystem_malloc.dylib (53.30.1) <DDA8928B-CC0D-3255-BD8A-3FEA0982B890> /usr/lib/system/libsystem_malloc.dylib
0x7fff8f4fc000 - 0x7fff8f55bfff com.apple.AE (681.5 - 681.7) <2BF39455-1CDD-392C-824A-9972C6B1FB57> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff8f55c000 - 0x7fff8f567ff7 com.apple.CrashReporterSupport (10.10 - 631) <C44259AC-0A1C-3EC5-99AC-48CB520A709D> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff8f621000 - 0x7fff8f625fff libCoreVMClient.dylib (79.1) <201EF6DF-5074-3CB7-A361-398CF957A264> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8f626000 - 0x7fff8f681ff7 libTIFF.dylib (1239) <B09E578A-D534-3A9B-9813-DAC9A0F230C7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff8f682000 - 0x7fff8f73dff7 com.apple.DiscRecording (9.0 - 9000.4.2) <4655B4B8-523D-3AE6-92A0-8486A2258B3B> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff8f747000 - 0x7fff8f839ff3 libxml2.2.dylib (26.1) <3FBA890F-2850-3A45-87EA-DB6892BDEB60> /usr/lib/libxml2.2.dylib
0x7fff8f867000 - 0x7fff8f86fffb libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
0x7fff8f8b2000 - 0x7fff8f8b7fff libsystem_stats.dylib (163.30.2) <D0E96837-3CF6-323D-B711-6DF6F660E530> /usr/lib/system/libsystem_stats.dylib
0x7fff8f8c0000 - 0x7fff8f8ebfff libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
0x7fff8f8f7000 - 0x7fff8f91cff7 libPng.dylib (1239) <BBB9FB25-3CA9-38AF-B88C-D6734693FEA1> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8f923000 - 0x7fff8f925ff7 libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8f926000 - 0x7fff8f92eff7 com.apple.AppleSRP (5.0 - 1) <68F0C577-ED96-34F2-B701-CE3023367D4D> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff902c0000 - 0x7fff90332fff com.apple.framework.IOKit (2.0.2 - 1050.20.2) <09C0518C-90DF-3FC3-96D6-34D35F72C8EF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff90333000 - 0x7fff9039ffff com.apple.framework.CoreWLAN (5.0 - 500.35.2) <03697149-1CDD-32FF-B564-1C1EF5E9E5C3> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff903a0000 - 0x7fff903a1ff3 libSystem.B.dylib (1213) <1866C519-C5F3-3D09-8C17-A8F703664521> /usr/lib/libSystem.B.dylib
0x7fff903a2000 - 0x7fff906a4ffb com.apple.GeoServices (1.0 - 1077.0.18) <2BBF8B44-DD46-3432-8C84-6D6AA004C233> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff906f1000 - 0x7fff906fdff7 com.apple.OpenDirectory (10.10 - 187) <D993F138-DAD1-3640-94DE-8C9FEFBF158D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff906ff000 - 0x7fff90737fff com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff90738000 - 0x7fff907a7fff com.apple.SearchKit (1.4.0 - 1.4.0) <80883BD1-C9BA-3794-A20E-476F94DD89A9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff907b3000 - 0x7fff907deff3 libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib
0x7fff907ea000 - 0x7fff907ffffb libCGInterfaces.dylib (294.1) <1A6AADE6-09EC-3054-85F9-E6A3607EBA70> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fff9080a000 - 0x7fff9080cfff libsystem_sandbox.dylib (358.20.5) <3F5E973F-C702-31AC-97BC-05F5C195683C> /usr/lib/system/libsystem_sandbox.dylib
0x7fff9080f000 - 0x7fff9080fff7 libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
0x7fff90857000 - 0x7fff908a6ff7 libcurl.4.dylib (83.40.2) <AE97ED1E-A58F-3EF0-8E88-DDC6AD409BCE> /usr/lib/libcurl.4.dylib
0x7fff90dd1000 - 0x7fff90dd4fff com.apple.xpc.ServiceManagement (1.0 - 1) <A95A15CD-3B21-3513-AFF8-1D7DE3DBFA12> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff90dd5000 - 0x7fff90ddefff libGFXShared.dylib (11.1.2) <7F9F6175-E993-3014-8C9B-1F08CE7C75A2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff90ddf000 - 0x7fff90e74ff7 com.apple.ColorSync (4.9.0 - 4.9.0) <9150C2B7-2E6E-3509-96EA-7B3F959F049E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff90ece000 - 0x7fff90ed2fff com.apple.TCC (1.0 - 1) <CCA42EE2-3400-3444-9486-BC454E60D944> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff9154c000 - 0x7fff9163fff7 libJP2.dylib (1239) <D346D67E-78A2-309D-94BB-C7C5FEC28785> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff91682000 - 0x7fff916affff com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff916b0000 - 0x7fff9183ffff libGLProgrammability.dylib (11.1.2) <11882D43-25B4-331D-9428-C97F4A88DA21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fff91840000 - 0x7fff91877ffb com.apple.LDAPFramework (2.4.28 - 194.5) <CAFB9695-000F-34EA-8DF5-09996929C26A> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff91878000 - 0x7fff91904fe7 libsystem_c.dylib (1044.40.1) <F0635E0F-FE4B-34DB-ACF9-A58C1E9070E9> /usr/lib/system/libsystem_c.dylib
0x7fff91905000 - 0x7fff91c0aff3 com.apple.HIToolbox (2.1.1 - 758.7) <E3129A67-BDF9-333D-9C9C-A95C8F0EF71C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff91c0b000 - 0x7fff91c25ff3 com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff91c26000 - 0x7fff91c26fff com.apple.Cocoa (6.8 - 21) <EAC0EA1E-3C62-3B28-A941-5D8B1E085FF8> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff91c84000 - 0x7fff91c95ff7 libz.1.dylib (55) <88C7C7DE-04B8-316F-8B74-ACD9F3DE1AA1> /usr/lib/libz.1.dylib
0x7fff91c96000 - 0x7fff91cb3ffb libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
0x7fff91cfe000 - 0x7fff91d07ff3 com.apple.CommonAuth (4.0 - 2.0) <9A484EE6-0003-3AB1-AE4F-AA543BBBF53F> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff91d08000 - 0x7fff91d24fff com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff91dbe000 - 0x7fff91dcbfff libxar.1.dylib (255) <7CD69BB5-97BA-3858-8A8B-2F33F129E6E7> /usr/lib/libxar.1.dylib
0x7fff92666000 - 0x7fff926acff7 libFontRegistry.dylib (134.1) <CE41D8C2-BEED-345C-BC4F-3775CC06C672> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff926ad000 - 0x7fff926affff com.apple.loginsupport (1.0 - 1) <DAAD7013-A19D-3858-BFF7-DE1DAF664401> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff92728000 - 0x7fff92730fe7 libcldcpuengine.dylib (2.4.5) <6CC680F9-0D13-333B-B151-F0D9C631A1E5> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff92731000 - 0x7fff928bffff libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff928c0000 - 0x7fff928c8ff7 com.apple.icloud.FindMyDevice (1.0 - 1) <9CE67F85-2BA8-3093-97BA-07BF5C04A5D6> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff928d9000 - 0x7fff928f3ff7 com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff92914000 - 0x7fff92926ff7 com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff92976000 - 0x7fff929aefff libsystem_network.dylib (412.20.3) <6105C134-6722-3C0A-A4CE-5E1261E2E1CC> /usr/lib/system/libsystem_network.dylib
0x7fff929e1000 - 0x7fff92a5afe7 libcorecrypto.dylib (233.30.1) <5779FFA0-4D9A-3AD4-B7F2-618227621DC8> /usr/lib/system/libcorecrypto.dylib
0x7fff92a8b000 - 0x7fff92a9cff3 libsystem_coretls.dylib (35.40.1) <155DA0A9-2046-332E-BFA3-D7974A51F731> /usr/lib/system/libsystem_coretls.dylib
0x7fff92a9d000 - 0x7fff92aafff7 com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff92bf0000 - 0x7fff92d9ffff GLEngine (11.1.2) <8A8153B1-94CE-3EC1-9840-441DA7217BA9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLEngine.bundle/GLEngine
0x7fff92dd5000 - 0x7fff92f85ff3 com.apple.QuartzCore (1.10 - 361.19) <F815B60E-75E3-3263-BE93-27A49882CF58> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff938cc000 - 0x7fff938d7ff7 libkxld.dylib (2782.40.9) <2ADAE067-78A0-371E-A5A8-1E7C892D193C> /usr/lib/system/libkxld.dylib
0x7fff938d8000 - 0x7fff938f1ff7 com.apple.CFOpenDirectory (10.10 - 187) <3FCEE6F7-A8C6-3222-B22D-8AD290E477E2> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff938f2000 - 0x7fff938f8ff7 libsystem_networkextension.dylib (167.40.3) <BA58B30B-8377-3B0A-8AE3-4F84021D9D4E> /usr/lib/system/libsystem_networkextension.dylib
0x7fff9394e000 - 0x7fff939baff3 com.apple.MMCS (1.3 - 327.5) <FC998246-ED60-334D-9E94-453F35EF9C78> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fff939bb000 - 0x7fff939bbfff libOpenScriptingUtil.dylib (162.2) <D6A2216D-ADB2-3F24-AD30-F6D00829F545> /usr/lib/libOpenScriptingUtil.dylib
0x7fff93a6c000 - 0x7fff93a6efff libsystem_configuration.dylib (699.40.2) <56F94DCE-DBDE-3615-8F07-DE6270D9F8BE> /usr/lib/system/libsystem_configuration.dylib
0x7fff93a7c000 - 0x7fff93e89ff7 libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff93e8a000 - 0x7fff93f02ff7 com.apple.SystemConfiguration (1.14.4 - 1.14) <3DFFD7F7-BD23-3F4C-A209-C4A0D99F6573> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff93f03000 - 0x7fff9401afe7 libvDSP.dylib (516) <DFEDB210-49D1-3803-88A2-C61DB6A45C3D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff94079000 - 0x7fff94079fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <B92888D0-ED3F-3430-8F3A-6E56FD16C5F1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff9503e000 - 0x7fff9508dff7 libstdc++.6.dylib (104.1) <803F6AC8-87DC-3E24-9E80-729B551F6FFF> /usr/lib/libstdc++.6.dylib
0x7fff950e5000 - 0x7fff95120fff com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff95121000 - 0x7fff951b2ff7 libCoreStorage.dylib (471.30.1) <9D95399F-1AC5-325F-8337-6E13AD99E44B> /usr/lib/libCoreStorage.dylib
0x7fff951d2000 - 0x7fff951d2fff com.apple.Accelerate (1.10 - Accelerate 1.10) <F1B96A61-7E4B-31BD-A35B-BA7EF1F16EF4> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff951d3000 - 0x7fff951dcfff libsystem_pthread.dylib (105.40.1) <ACE90967-ECD0-3251-AEEB-461E3C6414F7> /usr/lib/system/libsystem_pthread.dylib
0x7fff952c8000 - 0x7fff952ccfff libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
0x7fff952cd000 - 0x7fff952ceff7 libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
0x7fff952cf000 - 0x7fff9536dfff com.apple.Metadata (10.7.0 - 917.36) <00C4CB5D-E723-3612-84E0-439098392CDD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff95552000 - 0x7fff955f1e27 com.apple.AppleJPEG (1.0 - 1) <6627DDD9-A8FE-3968-B23A-B6A29AA3919A> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff955f2000 - 0x7fff955fefff com.apple.speech.synthesis.framework (5.3.11 - 5.3.11) <DFC7FD85-F1B0-317C-8513-722570CB8FB9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff955ff000 - 0x7fff95603fff libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
0x7fff95604000 - 0x7fff9562cfff libsystem_info.dylib (459.40.1) <2E16C4B3-A327-3957-9C41-143911979A1E> /usr/lib/system/libsystem_info.dylib
0x7fff9562d000 - 0x7fff95646ff3 com.apple.openscripting (1.6.4 - 162.2) <BF79207B-C762-346D-8FF0-3DDCECC9E9E2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff95654000 - 0x7fff956ddff7 com.apple.CoreSymbolication (3.1 - 57020.2) <FDAF88F6-7D11-37BC-B758-4B835FA657BA> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff956de000 - 0x7fff95f3dff7 com.apple.CoreGraphics (1.600.0 - 788.3) <875FBF24-D90E-36B1-9F7A-AF984E8943D9> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff95f3e000 - 0x7fff95f58ff7 liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
0x7fff9609e000 - 0x7fff960a4fff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff960a5000 - 0x7fff9643dff7 com.apple.CoreFoundation (6.9 - 1153.18) <5C0892B8-9691-341F-9279-CA3A74D59AA0> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff9643e000 - 0x7fff9645bfff libsystem_kernel.dylib (2782.40.9) <16AD15EF-3DAE-3F63-9D26-26CCE1920762> /usr/lib/system/libsystem_kernel.dylib
0x7fff964c2000 - 0x7fff9650fff7 com.apple.print.framework.PrintCore (10.3 - 451.1) <DE992474-0841-38A1-B4F6-46D653E454D5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff96551000 - 0x7fff96551fff com.apple.audio.units.AudioUnit (1.12 - 1.12) <E5335492-7EFE-31EA-BE72-4A9CEE68D58E> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff96552000 - 0x7fff96583ff7 com.apple.ProtectedCloudStorage (1.0 - 1) <9D76F2E0-C28A-3DBC-A91F-E87888D46BF0> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff96584000 - 0x7fff9658cfff libsystem_dnssd.dylib (576.30.4) <0CEB5910-843F-315C-A1DE-5D955A48A045> /usr/lib/system/libsystem_dnssd.dylib
0x7fff9658d000 - 0x7fff96590fff com.apple.IOSurface (97.4 - 97.4) <AE11CFBC-4D46-30F3-BEEC-4C8131079391> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff96591000 - 0x7fff9678b46f libobjc.A.dylib (647) <759E155D-BC42-3D4E-869B-6F57D477177C> /usr/lib/libobjc.A.dylib
0x7fff9678f000 - 0x7fff967e0fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <450293F7-DAE7-3DD0-8F7C-71FC2FD72627> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff96814000 - 0x7fff9685fff7 com.apple.CloudDocs (1.0 - 321.10) <A8221290-A2A5-3767-BB26-CC57AC18D4DC> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff96a27000 - 0x7fff96a34ff7 com.apple.SpeechRecognitionCore (2.1.2 - 2.1.2) <551322E2-C1E4-3378-A218-F362985E3E3C> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fff96a35000 - 0x7fff96a64ff7 com.apple.CoreServicesInternal (221.7.2 - 221.7.2) <B93D4775-149C-3698-B38C-9C50673D455C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff96a70000 - 0x7fff96ae4ffb com.apple.securityfoundation (6.0 - 55126) <AC8ED0BD-32F0-3EB8-B7B2-9AA14E07E8AB> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff96c1b000 - 0x7fff96c1dff7 com.apple.securityhi (9.0 - 55006) <2B9C0BCB-7D82-39C2-A99F-7B9E1522CDD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff96c46000 - 0x7fff96c4bffb libheimdal-asn1.dylib (398.40.1) <7D2BE3DE-60F7-3A6E-A92E-DA0EF9D3417E> /usr/lib/libheimdal-asn1.dylib
0x7fff96c4c000 - 0x7fff96c7cfff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
0x7fff96c7d000 - 0x7fff96cadff3 com.apple.GSS (4.0 - 2.0) <97F2A028-44CF-3188-B863-F4EEB39CBDBD> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff96cae000 - 0x7fff96cceff7 com.apple.MultitouchSupport.framework (264.6 - 264.6) <1539F1F6-6334-37F3-9C52-02EFFBF4835D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff96f67000 - 0x7fff970ceffb com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5678FC94-456A-3F5F-BA9A-10EB6E462997> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff970cf000 - 0x7fff970d0ffb libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
0x7fff9718e000 - 0x7fff9718eff7 liblaunch.dylib (559.40.1) <4F81CA3A-D2CE-3030-A89D-42F3DAD7BA8F> /usr/lib/system/liblaunch.dylib
0x7fff9723a000 - 0x7fff97245fff libGL.dylib (11.1.2) <FD8B7B67-1532-32A1-B369-9D7A6C1EB3ED> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff972e6000 - 0x7fff9730bff7 libJPEG.dylib (1239) <9AC25FD0-4190-3656-B8F5-6241D17105D0> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff97387000 - 0x7fff977dafc7 com.apple.vImage (8.0 - 8.0) <33BE7B31-72DB-3364-B37E-C322A32748C5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff977db000 - 0x7fff979c0ff7 libicucore.A.dylib (531.48) <3CD34752-B1F9-31D2-865D-B5B0F0BE3111> /usr/lib/libicucore.A.dylib
0x7fff97ab5000 - 0x7fff97ee5fff com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff97ee6000 - 0x7fff97ef1ff7 libcsfde.dylib (471.30.1) <A62AE3D8-E2A6-314A-BF45-804003BE0AC9> /usr/lib/libcsfde.dylib
0x7fff97ef2000 - 0x7fff97ef5ffb libCGXType.A.dylib (788.3) <7CC6CD5B-AD6B-3B36-9165-BFB1E5274F69> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff97ef6000 - 0x7fff97ef8ff7 libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
0x7fff97f2f000 - 0x7fff97f5aff7 com.apple.DictionaryServices (1.2 - 229.1) <62EC3E1B-5A28-3252-90FF-C2E9999C2A2A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff97f5b000 - 0x7fff981d1ff7 com.apple.security (7.0 - 57031.40.6) <FCCCC4FD-043A-30CA-9997-4211CA0E9297> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff981d2000 - 0x7fff98315fff libsqlite3.dylib (168.2) <BCB1F77E-2484-3EC4-A1D5-1AE90A407A23> /usr/lib/libsqlite3.dylib
0x7fff9832e000 - 0x7fff98412fff libcrypto.0.9.8.dylib (52.40.1) <D123FC57-E2EB-3E08-A51B-6C317EA83EB5> /usr/lib/libcrypto.0.9.8.dylib
0x7fff9859a000 - 0x7fff985b5ff7 libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
0x7fff985d5000 - 0x7fff9866bff7 com.apple.cloudkit.CloudKit (283.67.4 - 283.67.4) <EA6E4B2C-A3AA-3636-B9C3-F61D3EFFB82B> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff98683000 - 0x7fff98683fff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff98684000 - 0x7fff9879dffb com.apple.CoreText (352.0 - 454.10) <3293BF91-B587-3B49-A159-A04D58533F14> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff987a4000 - 0x7fff98a73ff3 com.apple.CoreImage (10.3.4) <C1AE8252-A95D-3BF4-83B8-BE85E979F2CB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff98a74000 - 0x7fff98da7ff7 libmecabra.dylib (666.7) <0ED8AE5E-7A5B-34A6-A2EE-2B852E60E1E2> /usr/lib/libmecabra.dylib
0x7fff98e93000 - 0x7fff98ecefff com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff98fc7000 - 0x7fff98fe1ff7 libextension.dylib (55.2) <3BB019CA-199A-36AC-AA22-14B562138545> /usr/lib/libextension.dylib
0x7fff99031000 - 0x7fff99318ffb com.apple.CoreServices.CarbonCore (1108.6 - 1108.6) <8953580E-7857-33B2-AA64-98296830D3A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff99319000 - 0x7fff99353ffb com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff99354000 - 0x7fff99356fff libRadiance.dylib (1239) <648BCB0C-55B5-3197-8F5F-81D5994B4EE7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff993da000 - 0x7fff995eaff7 com.apple.CFNetwork (720.5.7 - 720.5.7) <A47D7DD2-5903-39D0-8D27-5A7E2D119D84> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff99961000 - 0x7fff99971ff7 libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
0x7fff999d9000 - 0x7fff999efff7 libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
0x7fff99a1e000 - 0x7fff99d4ffff com.apple.Foundation (6.9 - 1154) <49EE64E1-9F53-35D1-A481-2EFE2789B254> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff99d50000 - 0x7fff99d55fff com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff99e22000 - 0x7fff99e46ff7 com.apple.Sharing (328.17 - 328.17) <AD5E243A-B79F-3D7B-800B-A2C99A1CFEF1> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff99e47000 - 0x7fff99e4efff com.apple.NetFS (6.0 - 4.0) <C263C8F8-F284-3101-AC82-A97A81716063> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff99e4f000 - 0x7fff99e51fff com.apple.EFILogin (2.0 - 2) <3BA837D8-94F5-3240-9CF7-E40DC2808446> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff9a538000 - 0x7fff9a53dff7 libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
0x7fff9a8a4000 - 0x7fff9a8f8fff libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
0x7fff9a9e5000 - 0x7fff9aa31fff com.apple.corelocation (1486.17 - 1615.24) <8825B3E2-E053-3E01-AE31-793443962D06> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff9aa32000 - 0x7fff9acb1ff7 com.apple.CoreData (111 - 526.3) <5A27E0D8-5E5A-335B-B3F6-2601C7B976FA> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff9acb2000 - 0x7fff9ada6fff libFontParser.dylib (134.7) <C49EDC56-A82A-39EF-9F20-C2342E4188ED> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff9ada7000 - 0x7fff9adf3ff7 libcups.2.dylib (408.2) <E8AD18F9-61E4-3791-B840-504468C25556> /usr/lib/libcups.2.dylib
0x7fff9aea4000 - 0x7fff9aeabff7 libCGCMS.A.dylib (788.3) <1A47CDD9-99AE-3BD2-85F1-339FC169B16E> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x7fff9aeb2000 - 0x7fff9aeb2ff7 libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
0x7fff9af5b000 - 0x7fff9b098fff com.apple.ImageIO.framework (3.3.0 - 1239) <CC904E44-45C4-389B-8FD7-4DF03C41C9EC> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff9b099000 - 0x7fff9b0f3ff7 com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff9b33a000 - 0x7fff9b33bfff libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
0x7fff9b33c000 - 0x7fff9b3bafff com.apple.CoreServices.OSServices (640.4 - 640.4) <BE8DF749-84BA-3029-AE1D-32F3993A78A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff9b3bb000 - 0x7fff9b3bdfff com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff9b3be000 - 0x7fff9b3c7ff7 libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
0x7fff9ba96000 - 0x7fff9bae0fff com.apple.HIServices (1.22 - 523) <E2F3C5FF-8C50-3E4F-BE63-77A700466663> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9bae1000 - 0x7fff9bbb7ff3 com.apple.DiskImagesFramework (10.10.5 - 398) <23E788A6-9A11-3232-A882-BA16D0C54880> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff9bbbf000 - 0x7fff9bbdefff com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff9bbdf000 - 0x7fff9bc07fff libRIP.A.dylib (788.3) <6AB1CA86-38C8-33E3-AC07-3A065666E0F9> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff9be20000 - 0x7fff9be26fff libsystem_trace.dylib (72.20.1) <840F5301-B55A-3078-90B9-FEFFD6CD741A> /usr/lib/system/libsystem_trace.dylib
0x7fff9be27000 - 0x7fff9be6dff7 libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
0x7fff9be6e000 - 0x7fff9c0ecff7 com.apple.RawCamera.bundle (6.04.1 - 798) <7988A25F-2A69-311E-929E-B70D164739F4> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff9c0ed000 - 0x7fff9c0f0ff7 libdyld.dylib (353.2.3) <CFBBE540-D503-3AFC-B5D6-644F1E69949B> /usr/lib/system/libdyld.dylib
0x7fff9c173000 - 0x7fff9c185ff7 libsasl2.2.dylib (194.1) <35371406-75EF-304A-A073-956C40373555> /usr/lib/libsasl2.2.dylib
0x7fff9c1a2000 - 0x7fff9c1ccff7 libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
0x7fff9c1cd000 - 0x7fff9c1d1fff com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff9c1d2000 - 0x7fff9c1edfff com.apple.AppleVPAFramework (1.4.5 - 1.4.5) <A6421B0B-6D4D-3E64-AC61-DDB04ED7CFF0> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff9c1ee000 - 0x7fff9c316ff7 com.apple.coreui (2.1 - 308.6) <9E0E9C6A-68F5-34C1-A17C-96226D401D4D> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff9c317000 - 0x7fff9c318fff com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff9c319000 - 0x7fff9c320ff7 libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
0x7fff9c357000 - 0x7fff9c3beffb com.apple.datadetectorscore (6.0 - 396.1.2) <D04A8016-B2AD-33A2-8A8E-5793968A8370> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff9c3bf000 - 0x7fff9c426ff7 com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff9c42f000 - 0x7fff9c46fff7 libGLImage.dylib (11.1.2) <9B05F3BF-D111-3B01-B7F8-C5EF7E02000B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff9c472000 - 0x7fff9c532ff7 com.apple.backup.framework (1.6.5 - 1.6.5) <86396038-33EA-3046-9F70-093A3D6407D4> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff9c574000 - 0x7fff9c577fff com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff9c5de000 - 0x7fff9c5e2ff7 libGIF.dylib (1239) <292BB418-F5C2-3D7B-AC1D-99082A4B88F3> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff9c662000 - 0x7fff9c662fff com.apple.Carbon (154 - 157) <9BF51672-1684-3FDE-A561-FC59A2864EF8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff9c663000 - 0x7fff9c689fff com.apple.ChunkingLibrary (2.1 - 163.6) <29D4CB95-42EF-34C6-8182-BDB6F7BB1E79> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff9c6a4000 - 0x7fff9c6affff libcommonCrypto.dylib (60061.30.1) <E789748D-F9A7-3CFF-B317-90DF348B1E95> /usr/lib/system/libcommonCrypto.dylib
0x7fff9cbb3000 - 0x7fff9cbddfff GLRendererFloat (11.1.2) <50EC0CD3-5CAB-3183-9818-FC4A405B681F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x7fff9cbde000 - 0x7fff9cca1ff7 libvMisc.dylib (516) <21497A28-8DCB-3EB8-BDAC-93C93382B0AA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff9cd1d000 - 0x7fff9cd34ff7 libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff9cd71000 - 0x7fff9cd76ff7 libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
0x7fff9cda7000 - 0x7fff9cdc8fff com.apple.framework.Apple80211 (10.3 - 1030.71.6) <C0A17391-5C8B-34B1-BD46-8D644AB57DE0> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff9cdc9000 - 0x7fff9cdf2ffb libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib
0x7fff9cdf3000 - 0x7fff9ce61ff3 com.apple.Heimdal (4.0 - 2.0) <8D1667CF-D454-3E07-A58E-E15591B5A95E> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 4
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 881
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=208.8M resident=113.1M(54%) swapped_out_or_unallocated=95.6M(46%)
Writable regions: Total=1.2G written=886.6M(73%) resident=1.0G(85%) swapped_out=0K(0%) unallocated=187.2M(15%)
REGION TYPE VIRTUAL
Activity Tracing 2048K
CG backing stores 9136K
CG image 1432K
CG shared images 240K
CoreAnimation 12K
CoreImage 8K
CoreUI image data 104K
Dispatch continuations 4096K
Foundation 4K
IOKit 102.9M
IOKit (reserved) 4096K reserved VM address space (unallocated)
Image IO 1024K
Kernel Alloc Once 8K
MALLOC 515.9M
MALLOC (admin) 32K
Memory Tag 242 12K
OpenCL 16K
OpenGL GLSL 256K
STACK GUARD 56.1M
Stack 15.2M
VM_ALLOCATE 551.1M
VM_ALLOCATE (reserved) 36K reserved VM address space (unallocated)
__DATA 19.4M
__GLSLBUILTINS 2588K
__IMAGE 528K
__LINKEDIT 76.1M
__TEXT 132.7M
__UNICODE 552K
mapped file 65.8M
shared memory 68K
TOTAL 1.5G
TOTAL, minus reserved VM space 1.5G
System Profile:
Graphics: ATI Radeon HD 2600 Pro, ATI,RadeonHD2600, PCIe, 256 MB
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.131.36.16)
Bluetooth: Version 4.3.6f3 16238, 3 services, 27 devices, 1 incoming serial ports
Thunderbolt Bus:
USB Device: Cruzer Edge
USB Device: Built-in iSight
USB Device: Bluetooth USB Host Controller
USB Device: ANT USB-m Stick
USB Device: BCM20702A0
USB Device: IR Receiver
Memory Module: BANK 0/DIMM0, 2 GB, DDR2 SDRAM, 667 MHz, 0x0000000000000000, 0x3235365836344D2D363745004B0000000000
Memory Module: BANK 1/DIMM1, 4 GB, DDR2 SDRAM, 667 MHz, 0x7F7F7F7F7F9B0000, 0x4354353132363441433636372E4D31364643
Parallel ATA Device: TOSHIBA MQ01ABD100, 1 TB
Serial ATA Device: Crucial_CT480M500SSD1, 480.1 GB
Network Service: Wi-Fi, AirPort, en1
Model: iMac7,1, BootROM IM71.007A.B03, 2 processors, Intel Core 2 Duo, 2.8 GHz, 6 GB, SMC 1.21f4
