I would recommend make sure your weight is correct and the same on all platforms and see if that makes a difference. You could have a weight set on one of the platforms too low and that could be confusing you in terms of data.
Hi Alex,
take a look at this, please:
https://m.youtube.com/watch?v=UzS6ZuWvmd4
I have Turbo Muin, too - but for Zwifting (and racing on Zwiftpower) I use a Power2max NGeco powermeter.
The sensor in the trainer does not measure power - it is a speed and cadence sensor.
Congrats on the weight loss Alex! Dropping from 91kg to 65kg is a big drop
Very helpful, thank you so much
Just put right weight… my 64,5 I have rounded to 65… now it’s floating 64-67… depends on the weather and menu ![]()
Thank you… I have never check the weight and after you mentioned it I have align/round up to 65 as 64,5-67 is floating weight
