Feature Request: Bring back static pace bots please
I don’t think this is a crazy idea. I don’t know if +1W/kg is the right number (probably not) but the dynamic pacing that exists now is both too dynamic and not dynamic enough at the same time, because it’s designed as “one size fits most”. But imagine if there were both static and “spicy” pacers instead of splitting the difference - this would not be a bad thing.
1w/kg = 100W for a 100kg rider + the difference between a 75kg bot and rider..
The bots should keep a steady pace. If you drop the bot on the climb then slow at the top and wait that is surly easier than (never) catching the bot again.
I would definitely prefer bots that ride constant power on the flats and uphills, but with teleport it really does not matter much. If you get dropped on a climb … teleport up. If you ride off the front … teleport back.
Of course, I don’t care one bit about the drops multiplier game.
I think you both know that static robopacers are not happening. Zwift has said that very clearly and gave the reason for it.
I have used the teleport a few times when the speed of the bot was getting excessively fast because it was drafting some 4.7-5.0w riders.
I’m pretty sure something has changed because the bot now finally doesn’t take off as fast as it used to in those cases. A number of the other Constance group regulars also noticed it a few weeks ago, that’s a good improvement.
I’m still hopeful for a WKO version bot based on eg. Zone2. Tweak in your settings your FTP bias or change your FTP to basically ride at whatever effort you want.
I had a rare thing today, I was in the London world with Constance and just one other robot rider doing 400w and 70rpm cadence for hours and hours (Zpower):
Once someone else towed the Zpower robot away from Constance it was just me and the robopacer and nobody else joined for the whole 80 minutes I was there.
The difference in pace and smoothness was enormous compared to Constance in Watopia with her team of “domestiques” (I saw someone call them that during the week) and the general blocking of the pack dynamics at times preventing you from smoothly overtaking others or having to surge to catch the robopacer back again.
Even with the usual variable robopacer power levels, this was so much smoother than normal.
I had to do that earlier in the week. I was with the Constance group in Watopia and the pace was all over the place, the sudden surges of speed had lots of people ending up 3-5 seconds away from the robopacer. Normally I wouldn’t teleport back but being tired, I couldn’t just steer away from everyone else then speed up and close the gap like I normally would.
The bots themselves have fairly predictable power, but it’s what happens when they get the draft of other riders. This is particularly evident with the very fast robopacers like Constance and to a slightly lesser degree Genie can take off very quickly at times if they get a good draft to follow. Few days ago the Constance group on Tick Tock was doing 44.8km/h average - very fast for that course. And the day before that did 43.7km/h average for Tick Tock.
If a small group stays about 3-5m in front of the robopacer with a bit more power they can speed up the robopacer quite a bit, enough to split the robopacer bunch, sometimes enough to drop everyone behind the robopacer (which they have to sprint to catch up). That’s probably what you are experiencing. And to a lesser degree the robopacer also carries a lot of speed into a climb because it has consistent power with no dips. It doesn’t need to change gears and have momentary lapses of power as we do while shifting (which loses a little bit of speed).
Just put the RoboBots on TT bikes. Easy-peasy…
If you want to reduce that delta you could always try riding with a slower RP than normal but on a gravel bike (assuming you’re riding on tarmac or equivalent surface)
The slowing effect of those knobbly tyres is a lot more significant at higher speeds, so once you hit the climbs it’s less of a factor. Overall, the power you need to put out to stay with the group will be less stochastic.
That 12 hour bot yesterday (which was with Constance group on Tempus Fugit) had a very good message it was saying in the chat:
At least while I was there, this ensured the pace didn’t start surging in a crazy manner. A few “superman” riders did join and started doing efforts at the front but they quickly backed off after seeing the message above (and others telling them to ease off).
With everyone staying at the robopacer the power needed to stay with the group was higher and the overall pace much smoother. This automatic message about keeping a smooth even pace could go to all the robopacers.
So if the robopacer didn’t react to draft of riders in front of it, it would be a lot smoother experience… what a novel thought… :face_with_hand_over_mouth:
I personally hate this feature request because when I read it the use case is either “I want to ride with people but be completely unaffected by them” or “this is faster than an erg workout”. Otherwise the solution is to simply ride an erg workout on a TT bike.
Everyone is of course different though. Maybe bots should be as well. Let’s add some are just a pure set power, some that surge way more for climbs, some that sprint for segments, some that ramp up and down over time. Maybe even some that are completely random, like bull riding. Give them real personality.
The only thing missing from that list is putting the robopacers on the big climbs, something that will really bring the dynamic pacing alive, don’t you think?
One of the problems with non-dynamic robopacers was getting dropped downhill, especially for lighter riders. Now that the draft-bug on ascents/descents is fixed, it might be another matter?
it could make sense to test steady-paced robopacers again!
Maybe have some bots that just make random turns at intersections instead of following fixed routes? You’d have to tie the people riding with it to their “choices” but it would add a lot of variety to riding with the pace partners.
The biggest problem there was with the very heavy older robopacers, ie 3.2w/kg Bowie Brevet at 80kg going downhill like a rocket, because it was very heavy.
Even old Amelia Anquetil at 4.2w/kg and 65kg was no issue on the downhills, even going down the Epic KOM, and I am lighter than that bot.
The robopacers still get dropped uphill, so the “dynamic” pacing didn’t solve that. I could get plenty of examples of Constance, Genie and Jacques getting destroyed up hills.
And there are now even more bots on multiple worlds, so there is obviously not an issue with too many options.
There are even 0.8w/kg bots no one is riding with.
I rode with the 0.8w/kg robopacer a few days after a cycling collision with a dog where I broke a couple of ribs. It was about all I could handle at the time.
How many riders rode with you and how many rode with the popular robopacers at that time?
Last time I looked it was like 3 to 5 who rode with a 0.8 robopacer and around 70-100 with the 2.2 or 2.6.
There were 4 or 5 others with the 0.8 robopacer.
I have no idea how many were with the “popular” robopacers - why would I even look at that when my only goal was to TRY to get on the bike and pedal a little bit after breaking a couple of ribs.
By your argument, the Constance robopacer should be done away with, since one time I looked there were ZERO other riders with it.
Would be cool if they developed a way to have a banded robo pacer group available all the time to fill in the gaps. Technically not a pacer at all since banded means no pace, but still it could toss you into a group on demand and you do whatever you want.
