Hey Jimmy, I took a look at your logs for your ride that day and I’m seeing an unusual amount of errors related to the BLE connection with your trainer.
I’m wondering if a poor connection is what’s causing the issues you described. The error is a bit generic, so it’s hard for me to identify exactly what might be wrong with the connection, but it may be a good idea to go through some of the troubleshooting steps here and/or try another connection type (either ZC as a bridge or using ANT+) and then keep an eye out to see if the problem still occurs.
Hi, is anyone having this problem anymore? Im on 1.20.1 on an Ipad and cant u-turn after completing Repack Ridge and heading south a short while to be able to enter Repack Ridge again. Also, my sterzo wont disable “steering all over the world” after completing Repack so it’s not really possible to continue after completing Repack.
Sorry if I have missed the answer in another thread or so but I have not found anything better or more applicable than this.
/T
As far as I know the U-turn work on PC and Companion app. On the companion app you need to hold it a bit longer and the avatar need to move at a certain minimum speed.
Thanks for reply. I was going 3mi up road to sky. Will it prevent u turn at a certain grades? It oddly decoded to turn around on its own about 10 minutes kater after I gave up on it.
