Button to change RPM bias during workout (or even skip mandatory RPM)
While we can already adjust the power in workouts, I would also really like to have a button to be able to change the RPM, like in steps of +5 and -5.
This ofcourse applies to workouts with mandatory RPM intervals.
Some workouts are just too crazy to be able to hold both the wattage and RPM together.
Too often you have to increase your power by 200%, for like only 10-15seconds, but also have to lower your RPM with 20, that is just not possible to do both in such a short period of time and still do a smooth interval.
I would even rather have the opportunity to skip the mandatory RPM all together.
And sometimes the mandatory range is just too high or low for anyones abilities.
RPM is already optional - not hitting RPM values won’t stop you getting the completion stars.
The workout transition you describe is a pain and not designed well to do on a trainer. On the road - just shift and hit it.
From a training perspective though, there’s no reason a normal healthy rider shouldn’t be able to learn to spin 130+. It’s easily trainable.
