For the past two to three weeks I’ve intermittently run into an issue where my Bluetooth module crashes when Zwift tries to connect to my paired devices. The only fix is a full power cycle of the PC (shutdown, unplug, wait, then restart) — a normal restart alone doesn’t bring Bluetooth back.
System:
- Windows 11, version 25H2
- Zwift: always kept on the latest version
- Motherboard: Gigabyte B660 Gaming X AX DDR4 (onboard Realtek RTL8852AE combo module — Wi-Fi over PCIe, Bluetooth over an internal USB connection)
Devices:
- Trainer: connected via Wi-Fi
- Zwift Click v2: Bluetooth
- HRM: Wahoo (older model), Bluetooth
Details:
- I can’t say for certain whether this started after a specific Zwift update or a Windows update — I have no reliable way to check that on my end.
- I’m not able to reproduce it 100% reliably, but as far as I can tell, it tends to happen on the second launch of Zwift if there hasn’t been a full PC restart in between. I’m not fully certain about this pattern though.
- This has so far only happened in connection with Zwift. I can connect/disconnect other Bluetooth peripherals (mouse, headphones) repeatedly without any issue, and MyWhoosh runs without any Bluetooth problems at all.
Has anyone else seen something similar, ideally with the same Realtek RTL8852AE chipset or a similarly combined Wi-Fi/Bluetooth module? Happy to provide log files or more details if that helps track this down.
