Iām going to say that an untrained cyclist doing an FTP test and then starting training plans makes zero sense.
Itās one of the many flaws of zwift if they are still doing the intro like that.
The best way to start cycling is to cycle lots of miles at a pace where you can comfortably chat to build an aerobic base. This is what is often called āzone 2ā or z2 pace. Itās more effort than a recovery ride, but these rides you wouldnāt find the biggest hills in your area.
What matters here is how far you cycle and how consistently you do it (i.e cycling every day is better than once a week) rather than how fast you are going or what.
That said, I wouldnāt take it too seriously, if you want to go and ride up a hill and put in more effort because itās fun, go for it.
As for cadence, generally prefer lower gears where you can spin the pedals comfortably. How fast you spin is mostly personal preference. The point is, cycling is, for the most part, a low impact cardio exercise - there are some exceptions to that (e.g track cyclists starting off in their fixed gear bike or big sprinting efforts) but, generally you should feel more out of breath as your efforts increase than as though youāre struggling to push the pedals around.
Sometimes IRL, of course, the gearing on our bikes and the size of hills means we have no other choice than to stand up and pedal unless we get off and push - in zwift you can limit the steepest climbs to match the gearing on your bike using the trainer difficulty setting.
When you start any exercise the fitness gains are relatively low hanging fruit and easy to get, thus thereās very little point in following strict training plans. Just cycling around in zwift or IRL enjoying the scenery will improve your fitness and the length of time you can cycle before getting fatigued will increase.
You should also find, by repeatedly riding at z2 pace your z2 pace actually gets faster, i.e you will be able to produce more watts at that pace for the same level of effort (i.e a similar heart rate) this is the sign that the training is working - and it can feel counterintuitive because cycling so you can chat feels easy some people think it isnāt giving them a good workout.
The trick is to make these rides long enough that you get fatigued - and then you will get fitter. The other advantage riding at z2 is that you recover quickly.
Eventually your fitness will plateau or the distance you have to ride at an easy pace will be longer than the time you have available. (Ultimately most people can get fit enough to ride all day at the ācycle so you can chatā pace - but few people will want to spend all day cycling so thereās maybe not a lot of point training z2 until you can - if you expect to ride max an hour or 2, then make your z2 rides this length - whereas if you expect to start doing longer 3-4 hour rides then train z2 until you can ride for 4 hours)
Usually the idea is to add 30 minutes a week. Training this way itās around 8 weeks training to do 100 mile ride which, again, you may have no interest in, but some cyclists do set as a goal.
At that point, then you can worry about measuring your ftp and things like training plans and workouts. Which would be a much longer post.
That said, if you want to do the training plans and they motivate you then go that route - the key training metric as a new cyclist is āride the bike a lotā - however you choose to ride it, indoors, outdoors, following a plan or doing what Iāve suggested above, the main this is to ride the bike a lot.
