I was just wondering whether there’s a way to set the camera view so that it cycles through the various angles automatically, thereby eliminating the need to press the corresponding keys. Such a feature would be of great benefit to me, because I have a movement disorder which makes it difficult to interact with the keyboard while riding.
I believe that if you are running ZWIFT on a PC there is a script you can run that mimics the key presses for you.
I think that is what some YouTubers use when they ‘live stream’ content.
I found a post by Eric Schlange containing a reference to “Victor Echo.” Included was a link to a zip archive containing an AutoHotKey script for sending the requisite keyboard codes for changing Zwift’s camera angles. I modified it a bit to add some features I wanted. I don’t know how to upload it with this reply. Perhaps I’ll just paste it into this document.
; Inspired by an original work by "Victor Echo", here is the result of my effort to enhance his work and add a couple
; of features. Specifically, this script cycles through the camera's viewing angles in random order. Additionally, the
; amount of time that elapses before a viewing angle changes varies. Finally, no camera angle is repeated twice in a
; row. In other words, the ensuing camera angle cannot be the same as the preceding one.
; There are a couple other features I would like to have added. For example, I wanted to implement more robust
; handling of Zwift's "Drone View." I never figured out how to get AutoHotKey to send the left, right, up and down
; keys while in Drone View. Finally, I wanted to implement a method for momentarily superimposing the name of the new
; viewing angle on the screen, each time the camera angle changed.
#NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases.
#Warn ; Enable warnings to assist with detecting common errors.
SendMode Input ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir% ; Ensures a consistent starting directory.
#InstallKeybdHook
#UseHook On
#IfWinActive ahk_exe ZwiftApp.exe
#1::
; The "Keys" array contains the names of the 10 keys used in Zwift to invoke various camera angles. The
; "Automated Zwift Camera Views" script cycles through these keys in random order. You may add or remove keys
; by modifying the array. For example, if you'd prefer to omit the "Helicopter chase perspective" view, simply
; remove "NumPad8" (including quotation marks and trailing comma) from the Keys array. Since the "Automated
; Zwift Camera Views" script selects elements from this array at random, you may add or remove elements in any
; order. In other words, ["NumPad1","NumPad2","NumPad3"] and ["NumPad3","NumPad1","NumPad2"] are functionally
; equivalent.
Keys := ["NumPad1","NumPad2","NumPad3","NumPad4","NumPad5","NumPad6","NumPad7","NumPad8","NumPad9","NumPad0"]
previousAngle := ""
loop
Random, index, 1, Keys.MaxIndex() ; Choose a number between the first and last indices of the Keys array,
nextAngle := "{" . Keys[index] . "}" ; and retrieve the key name at that index.
if (nextAngle = previousAngle) ; If the next camera angle is equal to the previous camera angle …
Continue ; … go around (i.e., start over).
; In the following statement, the "milliseconds" argument of the Random function will be set to a value
; that falls within the range specified by its second and third arguments. By default, that value would be
; between 15,000 milliseconds (i.e., 15 seconds) and 30,000 milliseconds (i.e., 30 seconds). The value of
; the milliseconds argument determines how long a particular camera angle persists. A new value for the
; milliseconds argument is selected each time the camera angle changes. The range from which this value is
; chosen can be customized by changing the second and third arguments accordingly. To make all camera
; angles change after the same interval, set the second and third arguments to the same value. For
; example, so that all camera angles will change after 20 seconds, invoke the Random function as follows:
; Random, milliseconds, 20000, 20000
Random, milliseconds, 15000, 30000 ; How long will Zwift maintain this camera angle?
Send, %nextAngle% ; Switch to the next camera angle.
Sleep milliseconds ; We'll loiter for a bit…
previousAngle := nextAngle ; Let's keep track of the last camera angle.
#2::Pause, Toggle
