It would be great to be able to drag and drop intervals etc and create our own run workouts (as in bike) Right now there are the three workouts to choose from and they are fine, just a bit vanilla. Perhaps this is in the works? Cheers.
I had abit of time to play with this now and here is my understanding of it. First here is a sample workout in .zwo format:
<workout_file>
<author>D.Hakansson</author>
<name>BikeToRun</name>
<description></description>
<sportType>run</sportType>
<tags/>
<workout>
<Warmup Duration=“1600” PowerLow=“0.6” PowerHigh=“0.75” pace=“0”/>
<SteadyState Duration=“5000” Power=“0.90” pace=“1”/>
<Cooldown Duration=“1600” PowerLow=“0.7” PowerHigh=“0.25” pace=“0”/>
</workout>
</workout_file>
The main parts here are the three lines inside the <workout>
I have metric choosen and the first part “Duration” is distance in meters. That means that in the choosen file I have 1600m(1mile) as Warmup, 5000m(3,1mi) as main set and another 1600m(1mile) as cooldown.
The next part is twofold the: "PowerLow=“0.6” PowerHigh=“0.75"” means that the workout goes from a 0.6 effort to a 0.75 effort of the choosen pace. Pace is selected lastly on those lines with a number from 0-4 (pace=“0”)
0=Mile pace, 1=5k Pace, 2=10k pace, 3=HM Pace, 4=M Pace
So my workout is simply a Warmup that builds from 60% to 75% of my mile pace during 1600m
After this is the main set a 5k at steady state at 90% of my 5k pace
Finally there´s a cooldown from 70% to 25% of my Mile pace
If I wanted this in a 2x2,5k format instead I would change the <SteadyState Duration> to 2500 and add another line exactly like that one directly below:
<workout>
<SteadyState Duration=“2500” Power=“0.90” pace=“1”/>
</workout>
And if I wanted to increase my speed on tht second steady state to 95% of my 5k pace duration I would simply edit like this:
<workout>
<SteadyState Duration=“2500” Power=“0.95” pace=“1”/>
</workout>
Hopefully this can help afew build run workouts. Remember though that Zwift needs to be restarted if you edit a workout or else it won´t read the edits you make.
Happy zwifting!
