I have a few question on sensors and power meters (pedals and trainer). I have the following setup.
Power Meter Pedals: Garmin Vector
Smart Trainer: Tacx Vortex
Speed/Cadence: Combo Sensor
- Why do my cadence readings vary depending on the sensor? Before I begin my ride I have the option to select any of the above for cadence. When I select the pedals or trainer both readings are almost identical if not the same however if I select the combo speed/cadence sensor it varies quite a bit. Pedals/Trainer ~80 vs Combo sensor ~105+. The measurement however only varies on Zwift. If I record my activity on my Edge and Fenix I get the same cadence reading on both devices.
- Power Meter variances? I know there’s some smoothing being done on Zwift however I’m not entirely sure how much. I haven’t had my pedals very long, and just bought my trainer, so I’m still learning about power. I calibrate both the trainer and pedals before each ride but readings vary quite a bit. I should note, I use the trainer with Zwift as well as record my workout on the Edge using the Vector pedals. Any ideas or suggestions as to what I should do or focus on? ie. Zwift or Edge recordings?
- Given that the “Smart Trainer” broadcasts all important variables (Power, Cadence, and controlled by Zwift) should I simply set the software to use it for each setting?
Thanks in advance.
