Brilliant!
Oh my giddy aunt⦠This is going to be amazing!!!
Did this get anywhere for a more permanent solution?
Hi Shuji, I tried this but it didnāt last and the names reverted back to default shortly after.
Ah well, I hope there is an update that allows this facility soon!!!
Also, shameless bump ![]()
- Are you on PC/Mac? It will not work for iOS / Android / tvOS.
- Are you on the same PC/Mac, or did you switch to a different one? Your customized knowndevices.xml file is stored on that local machine only, (i.e. it wonāt sync across devices).
Hi dude,
Yeah, same PC each time!!
Iām going to try again but would love a official in game way of doi g it ![]()
Thanks for you help with this.
Vote for me from this, it would be really useful - Iām on iOS/iPadOS so the āhackā isnāt an option anyway
Adding my āyes, please!ā to this request.
Hi Shuji,
Each time I try the āhackā to name equipment, it works first time but subsequently reverts back!
Is it something Iām doing wrong? I had previously removed all equipment from the file (starting it from scratch).
Thsbks
Tim
Shameless bump ad nauseum!
Bumping again so it doesnāt disappear!!!
I have 2 pairs of Zwiftplay controllers, and ride with my 10 y.o. son both irl and in Zwift at the same time, running 2 instances of Zwift on the one PC. Pairing the devices isnāt difficult but remembering which of the 4 device IDs is whose, is!
It would be really great to be able to rename them to something easy like B-Left B-Right and F-Left and F-Right, and have it remember/recognise and use the new device name each time we connect.
When I pair devices to my Garmin watch via Bluetooth I can edit the device name easily on the watch. This should be a breeze for the Zwift team - allow device to be renamed when paired, or even marked as favourite.
Thanks for your help.
It seems such a simple feature. Surprised that it doesnāt get recognised!
Anything that involves editing files is a missing feature. There are platforms that run Zwift where you canāt edit files.
please add a proper solution for this. I have his and hers kickr bikes, HR, Zwiftplay etc that are used at the same time. We sort of remember the IDs but renaming would be great
Iām just going to bump this again!
@shooj ās trick works with Bluetooth devices but ANT+ devices every back once they connect.
With all the resource allocated to development, I hope a little bit is allocated for this feature.
I have to say this is exactly the feature I need. I have 4 Zwifters in our house and 4 Wahoo trainers. Naming the trainers would make it so much easier to connect.
Agreed, The ability to name devices as well as select the preferred default device would be great additions.
Yeah, this would be really handy!
Uh, this needs another BUMP I guess! Can we have that renaming feature, pretty please?
Chris
