I did an Bike Fitting for my Canyon Grizl and want to “convert” the measurements to my Zwift Ride.
Is there like an “scala” where I can adjust the Zwift Ride to my values?
Hi @Kim_Speda
Thanks for sharing your question. This is Haziel from Zwift Support. I understand that you want to translate your Canyon Grizl bike fitting into your Zwift Ride setup for your comfort.
While there isn’t a direct one‑to‑one “scale” that converts outdoor bike geometry into Zwift Ride measurements, Zwift does provide a fit chart that works as a baseline. I recomend you to check this article: Adjusting Your Zwift Ride. It provides a guide that correlates rider height with recommended settings for saddle height, handlebar reach, and bar height.
From there, you can make adjustments to tailor your Zwift Ride setup to better reflect your Canyon Grizl fitting numbers. Although the process requires some fine-tuning, I’m confident you’ll find a comfortable setup that feels right for you.
If you have any more questions or need further assistance, please don’t hesitate to reach out. We’re here to help!
