Is there a way to take gpx data, or some type of ride data and import it into a Zwift ride? I don’t really care what the scenery looks like if the ride elevations are accurate.
Not at this time.
Hi Jeff,
We do not support this feature at this time and have no current plans to.
You can take your GPX/Fit data and convert it into a Zwift workout, and ride that, however…
What won’t work, is matching that GPX difficulty to the actual terrain rendered in Zwift. In other words, your GPX data may show you climbing a steep climb for 30 minutes, while on Zwift, you may end up “climbing” that section while the screen itself shows you motoring across a flat section of road.
Check the “Zwift Workouts” group on Facebook for the tools to convert and manage your data as workouts.
It’s not ideal, but it may get you closer to where you want to be.
