It isn’t, you aren’t thinking about how it affects everything, you’re thinking about the selfish solution it gives for you as a solo rider.
As said; you can’t approach the RP’s with a change like this which grants a single solution for one person, and creates 5 more for others.
You say that if you set your height and weight to Coco; you won’t get dropped.
But you’re talking about a system that dynamically changes your height and weight (aka “cheats” physics), in a temporary hoola hoop space around bots; just so you can hang with a single bot…
Yes you’re talking about it being a checkbox, which is individual… but here’s where things go wrong.
If you’re talking about saying you have to cheat your weight, to ride with a bot, that means you’re now cheating your w/kg, and when you’re doing that, it generally means you’re going to be pulling more power than what most people will expect.
I warm up with Coco; do you know how often I’ve had to drop from riding with Coco because of so many high powered front-runners ruining the pack speed?
LOTS
Again, you aren’t looking full picture and how it affects OTHER people.
By more / heavier people that join Coco, basically means people like me who are used to a specific pace, are confused and can no longer ride with Coco, because she’s being pulled along like a time trialist by people rocking 300 watts out the nose of the group, increasing the ground speed by 2-3mph more.
What it sounds to me like is that you want a RP that doesn’t have climbs because the w/kg gets too high on the climbing sections.
So… better solution:
- RPs that don’t dynamically change their power.
- RPs that are on Tempus Fugit (or a new world/location) 24/7
Neither of those solutions give others problems; like what you’re talking about.
I hope what I’m saying makes sense about how EVERYTHING affects others; and some solutions for some folks, create bigger issues for so many others.
You may not think this is the case; but I can assure you, and ZHQ (or even just searching on this forum), there is plenty of data of how fast some RPs are some days versus others; and it purely comes down to high power folks, sitting out front of the RP dragging them along.
Instead of going to a different bot.
If anything; there could be a popup saying “Hey it looks like you’re riding out the front too much, would you like to go to a faster bot?”
