So recently, the game has been updated to have the default ‘start’ gear being gear 8 when you’re utilizing virtual shifting. As someone who enjoyed starting on gear 12 (and typically shifted up immediately to 15 to start), this change caused a bit of consternation, but I didn’t see how it’d be problematic.
Until now. Now I see how it’s VERY problematic.
This involves workouts and the automatic cycling of ERG mode.
When in workouts you hit a ‘free-ride’ effort where you expect to go full-gas (ie: 15 second sprint intervals), the sudden jump from a cozy spin in ERG mode on your ramp up to next to no resistance (Gear 8) when ERG mode turns off is terrible to put it mildly! Stepping up through the gears, having enough delay so that the game and virtual shifting can properly walk up through the virtual cassette, leaves you with little to no time in that 15 second block to put in actual effort (for me, this is typically around gear 20-22). Running yourself up the cassette from 8 to 20 is an entirely different problem - the game doesn’t compute the inputs immediately, and once lag-time is over, it gives you ALL of the resistance at once. It pretty much slams you from NO resistance (8) to ALL resistance (24) and then dials back to 20 - I found this out the hard way, and ended up standing with all my body weight on one pedal and barely getting the blasted thing to move because the sudden plunking of all the world’s resistance brought my cadence to a screaming halt.
The only way around this is to turn off ERG preemptively and then remember to toggle it back on once your’e done with the free-ride set, but if you’re deep into a painful workout, remembering to do this sometimes doesn’t happen, leaving a rider with the same spin-out issues when free-ride segments occur.
Why, oh why, can we not have an option in Settings for virtual shifting to set our own default gear?! I would LOVE to set gear 15 as my start. I’m sure there are other riders who’d appreciate the same. And those who wanted gear 8 can have gear 8. Heck, we could make it that gear 8 is the default, and those of us who want something different have to go and actively alter that setting in the settings menu.
Please, PLEASE give us an option like this. The dialing back to gear 8 in workout mode every time ERG turns off is ridiculous.
