Same for me… build me up not crediting. I use AppleTV/ZC App
Same issue with Gravel Grinder. Once the workout is finished it disappears from the Companion workout plan until I go to the workout menu and select “I did it” and then it appears back in the workout menu in Companion.
I have the same issue with the 13.1 mile running training plan since last Friday. I had the workout not show as completed in the training plan. It was the week 3 long run (8 mi). The companion app and Strava show the proper workout title. Manually marking the workout completed does not give me my star ratings nor map my workout to the activity in the training plan. It says I completed the workout outside.
It happened again today with my week 4 optional easy workout.
This started occurring since the app updated last Thursday night.
The workout seems to not be correctly being marked as completed when there is a single workout to complete on a given day. I fear this will happen again on Friday when my single long run is only available.
When I had three workouts to choose from on Monday and two workouts to choose from on Tuesday, the daily workout I chose properly got marked as completed.
i used the Singlerack slayer workout
where van i find the progress bar ?
I’ve had the same issue in 6wk beginner FTP Builder. I’m on Apple iPhone so haven’t seen the update arrive yet for iOS. Ticked the ‘I did It’ tab in bottom rh corner when viewing the plan in the Zwift app, which worked.
Me too in Dirt Destr . The issue start from 3 week
Bugs happen - as a former developer dog knows I’ve created a few in my time - but the lack of information from Zwift on what the issues is & when it’ll be fixed (both on this thread & via email when I reported it) is really disappointing.
Experiencing the same issue. - If you take a look at my Zwift power report you will notice the name of the program has changed it just said FTP Builder before and now coinciding with this issue it has changed to Zwift- 6wk Beginner… just saying this matches to when the issue began for me.
I have exactly the same issue.
I have the exact same issue. in week 6 of the build me up training plan. Completed the 15.9 workout on Tuesday and it did not reflect in the training plan, so marked it completed manually. Did the C.A. workout last night and now it isn’t even showing up in my training plan. Hope zwift comes to a resolution soon.
Agreed, software dev/ bug fixer at heart! Seems this last push to production left staging to quick, QA much lol?
Has been happening to me as well. From middle of week 6th on Build Me Up plan, any of my exercises are not completed anymore and I have to manually complete them.
Very frustrating!
Gang - we’re aware of the extent of this problem and are working to fix it as soon as possible.
We appreciate your patience - in the meantime, please use the workaround in the first post above.
@shooj will we be informed when it’s fixed???
@Ian_Robertson3
Yes. I will post on this thread when it’s fixed.
There are several threads about this issue. I will probably do some housekeeping and merge them when it’s resovled.
Good man @shooj, thank you.
Also seeing this issue with the Zwift Racing plan. Did the workouts this week (2 x Watopia Hilly Reverse) and Taking it easy, and none of the three show up in my training plan, although all the show up in the Zwift Companion app.
I hope part of the fix will allow for these workouts to be recorded back in the training plan, so progress isn’t lost or needs to be repeated.
Same issue for me in the Build Me up 12wks.
It started after the latest software update.
Whilst that’s good to hear, at this point, someone at ZWIFT needs to explain
- What the problem is
- What platforms it affects
- When they anticipate releasing a fix.
This is all pretty basic stuff
Just chiming in that I am experiencing same issue with FTP Beginner plan. I have been manually indicating that I have completed segments but wonder if and when that data will be overwritten with actual data from my ride history. Should we be manually updating?
I share the impatience and frustration of others with the radio silence from Zwift. Or am I missing something?
