Thanks guys.
Glad I wrote up what I was seeing now!
The last time this was reported I believe it was a version mismatch like you pointed out.
@xflintx - Is the plan to roll out PD4.1 once everyone has a chance to get the latest update (1.46)?
going to be switched on Sunday night Pacific time
It has been confirmed here Eric.
But yes, I guess this fits with everyone ensuring they are on latest version before making it fully live
since it is already in use in Makuri, Iâm guessing it is just a server side switch and the game client already has the necessary code.
For everyone to get on the latest update is one consideration yes. The other is that the Pacers reset every week on Sunday night PST/Monday morning EU/UTC, and enabling it just ahead of Pacer reset will ensure there is no odd behavior in those groups due to differences in pack dynamics versions, which is something weâve seen in the past.
Can you give a recap on the functional changes from PD4.0-4.1. There has been a lot of minor adjustments between the 2 during that time frame.
Also is PD4.2 or PD 5 going to be in the works after PD4.1 launches?
see 1.46 update thread
[quote=âMike, post:524, topic:607051, full:true, username:Mike_Rowe1â]
Can we elaborate more on what is âattackingâ vs âhigh Draft situationâ
The two are not mutually exclusive. Rider A pushing 1000 watts at 55mph, with rider B doing 900 watts at 56 mph on his wheel, is both in a situation where the rider is attacking and in a high draft situation.
Good to see the updates!
Hoping to see
Less CdA penalty to large riders. IRL I can hit 40 MPH on barely -2 deg downhill easy, in Zwift I full on sprint into a -6 degree downhill and barely break 30MPH.
Much less hysteresis in large packs. Riding in a large peloton right now is like a freaking bouncy castle, youâre way off the front for 2 seconds then way off the back completely dropped in the next 2 seconds. Less flying off the front then shooting off the back and rinse and repeat would be much better experience.
More instantaneous response to increase in power. There was that test from GPLama that Wahoo direct connect power is an advantage due to 10hz refresh rate on power, vs 1 second. This is simply a well known side effect of Euler integration with different step sizes. Good news is you can make some assumptions here about the substeps by looking at how people ride IRL. So go make some assumptions about the substeps.
No, unless something egregious needs to be fixed. PD4.1 should be solid for quite some time into the future.
Think to real life racing for the examples here: attacking would be attempting to break from the group for your first breakaway, attacking the breakaway, attacking on a climb, etc. Essentially any instance where youâre attempting to dislodge yourself - either solo or with some additional riders - from any other group. High draft would be around a lot of people.
The two will have some overlap as you point out, and the changes should account for that.
Happy to read that we can close this topic soonâŚTest Events are in the past
Yes they are mutually exclusive. Because âattackingâ is only a situation considered when you are not drafting.
By the way, speaking of dynamic CdA changes. One thing I forgot to mention.
They are not applied in Time Trials, either team or individual.
There are plenty of times we are attacking, we are also in draft.
Is âattackingâ still defined as increasing your power over your last 10s average?
Iâd worry less about the specifics and actually try some PD4.1 races and see how it feels. If it feels fair and fun then that is the main thing.
From a PD4 race but itâs the same brake as is in 4.1 and the PD4 thread is dead. Watch as I get braked, at 315w, while steering across the back of the field.
You are cruising with 0 Watt, accelerating to 331 Watts and steering across - perhaps you were to fast and would ride in another rider from behind (the gap seems to be very small)?
I was moving into open space in the back of the pack. âGoing from high to low draftâ is supposed to keep you from cruising through the front of the pack. To brake people at the back moving into open space is inappropriate.
Plus all along Iâve complained of getting braked at the back and side (I have a clip of that from today too) and told that itâs not actually happening or a problem.
