Probably need to turn it off at the Logon pairing screen. I’m riding a Kickr Bike too and if I don’t turn off steering at that point, my HRM doesn’t work for the entire event. I can turn it on later from the Menu screen and everything is fine. Weird…
Tried logging off and on again and doing just that, but didn’t work for me. But good suggestion👍
Maybe a complete shut down and reboot?
Do you ever have problems with your HRM during events with steering turned on?
Never had problems with HR.
Tried again with complete shut down and as long as I don’t pair it as «controllable» I don’t have the wheel. But if I do, even without steering, I get the wheel during free ride.
@Stian_Lersveen
Caveat: I don’t have a KICKR bike.
Is this any help? Steering with a KICKR BIKE
See step 4 at the end.
Thanks for the suggestion, but think this is what I’m trying to do.
And I can’t be sure if these problems are related to steering or not, but have a feeling they could be.
+1 from me. I had the exact same thing, had my screenshots ready to post and everything
I have the KICKR Bike too and was paired with Steering on (BLE). I noticed this was happening a lot whether I was steering or not - and this was in free riding with Coco. Inside an event, with steering disabled, everything was normal.
The movement is a bit jerky and abnormal. Bike positioning is definitely unnatural, you are moving forward but the bike is angled at about 30 degrees or 1o’clock / 1:30 on a watchface.
Doesn’t seem to affect anything - just an optics issue by the looks of it.
@Stian_Lersveen
Sorry, hope I’m not clogging up the thread, but just to be sure we’re talking about the same thing, it’s about de-selecting the steering possibility on the left (i.e. leaving it orange), I believe:
Getting back to your observations, and those of @Jeff_Hinds_758151, I found that riding in PD 3.0 without steering enabled, the interaction of my avatar with others was more fluid than later in the same world when I had steering enabled (Elite Sterzo Smart).
With the steering enabled, the most awkward-looking part was what you’ve both pointed out: one’s avatar stiffly points in an unnatural direction, often while you’re butting up against another avatar, as you both carry on riding forward. I agree that this is probably purely a visual thing and likely doesn’t affect one’s speed/draft coverage, etc.
One other thing that I found interesting was riding in PD 3.0 with steering enabled, but keeping the handlebars centred for an extended time. I think that the system takes control after a certain time and treats the avatar as if steering has been de-activated. As soon as the bars are turned, the system steering takes back control. (IIRC, that was introduced a while back in one of the major Zwift updates, but then got buried due to bigger issues.) But I could be completely wrong and have misinterpreted what I observed on screen and what I read in the notes.
Yes, this is what I’m talking about. But even if steering is not selected in the pairing screen, I still have a «wheel» by my name suggesting that it’s on.
And when I think about there were some other interesting stuff that happened during the ride…
First 30 min I had steering «on», but didn’t use it. I think my rider then behaved nicely as if it was turned off, but still had the visual «turning».
Next 30 mins I turned steering off in the pairing screen. It then seemed to not work well at all as my rider ended up outside the draft a lot of the time. Often I rode by myself at one side of the road while everyone else was nicely grouped up on the other side.
That certainly suggests that something’s not right. Or is it a quirk of the KICKR Bike in Zwift? Whatever the case, your observations of those two 30-minute blocks look like the opposite of what would be expected, right?
When I was in the group ride in London last night (no steering devices allowed), avatars were all drafting naturally and no one was being excluded from the draft if they were anywhere close to other riders. I haven’t tried riding with steering with Pace Partners myself since PD 3.0 were activated in Watopia, but might try to reproduce your experience tonight after another group ride.
I think it’s a quirk of the kickr bike. If the visual is fixed I think this most likely will work roughly same as before. And in events when steering is disabled it will probably work as expected (will hopefully test that tomorrow).
Will be interesting to see if you can reproduce the issues.
rode today with Carly bot and Bowie bot. overall, the PD3.0 feels much better. i’m not constantly having to overcome riders slowing down off the back of the pack or putting out slightly less power than me, and i can react more quickly to a change in my position in the pack. riding uphill in particular requires less power now in a group, and riding downhill with bowie doesn’t require me to redline to stay with him.
i think one “unintended consequence” here is that a bunch of C riders are going to realize they are now B riders (such as myself). i was much more able to keep up with Bowie today, even going up the volcano. the power was still high, but it was more even – which means that i didn’t have to spike my power periodically to keep up. and not spiking my power means i was able to keep my HR more under control. particularly on flat sections, i was able to sit up for a second and lower my HR without getting pulled out the back of the pack.
couple odd things:
- my avatar did seem to hug far to the right of the road – even riding in the grass. there was one point where my avatar was far over to the right and seemed to want to get back on the road, but there were other riders blocking. the result was i was sort of drifting on a diagnol until it sorted out.
- i rode with carly first, then switched to bowie. when i did this, it started me very far from the bot, and then there was a HUGE pedal assist that blasted me around watopia until i caught up with him. not sure if this had anything to do with PD3.0, but i’ve never seen that before.
Rode the Pack Sub 2.0 ride on London’s Pretzel (Got DQ’d but I knew that was gonna happen with those guys) so I could try out PD3.0 in different packs. There are usually three or four packs of 10-20 miscreants each who ride off the front so I could switch bikes between each pack and see how it responds to the changes. I can say for me, PD3.0 is the single biggest improvement, on the order of “End ride and start another without logging off” change, I’ve experienced on Zwift.
The lack of lateral movement, how the avatar has some idea of what a correct line is through a corner, and most of all, the reduction in sticky draft, all make this a HUGE improvement. It so much more like Real Life that it seems like an entirely different game. If anything, I felt like I was slower because of how steady everyone was within the pack.
When riders in front went over a hill, you didn’t have to hit the 15 second power to hang, we all just stick together as a bunch and power down.
I followed the Pack ride with a freeride on Makuri Farmland Loop with steering. Not really enough Zwifters to get an idea of how steering works in a group but it was still better than anything we’ve had before.
Kudos to ZHQ for the upgrade. This is absolutely the best present ever! Thank you.
My SZR Endurance ride in London was on the whole okay today, unless you were part of my sweep team (I’m waiting for a full report back, but it sounded challenging). I had a nice blob around me too.
Apologies for not reading the previous posts my issues may have been mentioned already.
The fun really began on the after party, basically 9 of us all had similar issues and the group was blown apart by the end:
unable to make U turns
indicated directions were not the ones we ended up going at a junction
speed limiter of 24kph kicked in for at least 3 of us on Fox or Box declines then stayed in place to the end of the ride.
Needed to ride to 162km today, 10km to go I was FORCED up Box Hill for a second time, not exactly what I needed
All this is available on my livestream if needed.
Heard it was an Alpe issue, but thanks.
Hi Paul,
Discussion of the u-turn bug was focussed on the AdZ because people were being stopped from vEvesting by the issue and generally make their attempts on the Alpe.
Unfortunately, it looks like we won’t see a bug fix for that being published until around 10 Nov. Until then, avoid attempting any u-turns after completing any route in the list of badge-winning routes (even if you have the badge already).
Luckily, the u-turn bug seems to be unrelated to the Pack Dynamics 3.0.
@Stian_Lersveen can confirm I see the same behavior with my Kickr Bike tonight during an After Party ride in Watopia. When you get pushed to the edge of the road the avatar seems to want to go back in the road but other rides in the way and you end up at an angle for a bit before it sorts itself out.
Also seems that with steering (even if not using) you get set to the outside of the group more than others without steering.
@Roule_Thoune @Stian_Lersveen @D_Watson We might want to pair in ANT+ with which steering is completely disabled, IE: does not exist, and see if that makes a difference from where there is a possibility of steering with BLE. Really, I’m fairly lit and grasping at straws but that’s all I got… Dang that was good Scotch this evening…
