Hello all-I would like to use my Macbook Pro for Zwift. I know nothing when it comes to specs and I’m hoping one of y’all may be able to help. Here’s a screenshot of my system:
Here you go! Looks like you are good to me give it a go!
What are the minimum computer requirements for Zwift?
Eric C.
July 27, 2015 16:58
Here are the current minimum requirements in order to run Zwift:
- OS : Windows 7 x64 bit, OSX 10.7
- Processor : Intel Core 2 Duo
- Memory : 4GB
- Graphics : 1GB dedicated GPU, or embedded Intel HD 4000/AMD R5
- Hard Drive : 4GB of free space
Like most video games, Zwift primarily runs off your computer’s graphics card or chipset. Even if your CPU and memory are far above our minimum requirements, you may still be unable to load Zwift if your GPU is below our minimum spec.
Not sure where your GPU stands? You can see a ranking of GPUs on http://www.videocardbenchmark.net/and compare our examples of minimum requirement models against your own.
For a full list of minimum, recommended, and extreme specs, check out the Supported Platforms section of our website.
I’ve run it on my old MacBook from 2010 and it’s choppy…but gets the job done so I’m sure you’re fine ![]()
