Hi has anyone recently compared the zpower output in zwift for a KK Road machine to “actual power” from power meters, like Stages or Garmin Vector?
I’m curious if the zpower readings I’m getting in zwift are way off or not ![]()
We have! And it’s pretty close
zPower will always be a work-in-progress but, right now, the KKRM is quite accurate as long as your set-up is correct.
After breaking a belt on my Kickr, I was forced to use my Kurt Kinetic Road Machine for a few rides. I also have a powertap rear wheel so can get power. I have Zwift setup to use the speed sensor with zPower rather than the powertap so I could compare. The average power for the ride from the powertap was within 2% of that I got with zPower. I was surprised and impressed.
Hi guys ,my setup is following :
-Kurt Kinetic Road machine (non smart)
-Garmin Speed Sensor and Cadence Sensor (magnet-less version)
-Garmin HR strap
-Schwalbe Insider Turbo Trainer Tyre 25 mm
I would like to know if is possible how is the best setup in order to approximate W closed to reality in Zwift
-How many turns for back knob on the back wheel ?
-What pressure to inflate rear tyre ?
Thank you very much
