Introducing Zwift Video
Jausiers side :+1:
I really enjoyed the ride. Made a nice change.
I think they need to improve rider density by having a “ride of the day”. Since so many people seem to care about XP and things like that, they should increase those for participation. They could have a bonus for doing three routes per week.
I think there are some technical complications with putting something dynamic (like the workout arches) into the video, but it works ok for the static items, like climb starts and finishes.
Flawless the first part of the route. After a fast downhill, it started buffering. it took 2-3 minutes to get the video and the it’s on and off.
What’s the cause of the buffering?
Network? I thought it downloaded the whole map in the beginning. It’s a small route. Even so, I am hitting speeds between 100 and 400 Mbps.
Hardware? MacBook Pro with M1 Pro and 32 MB ram should not have issues at 1080p I run it.
Any ideas?
That might be the case. I don’t think they can separate traffic (like real cars and trucks) from the background easily to go through the transparent arches for example, because it’s all part of the same “flat” video. That’s what I was thinking about, but I’m not a developer.
It’s a download issue on your side. It only downloads an initial portion of the route at the start of the ride, and needs to keep downloading more in order to stream the video smoothly.
When you say you’re hitting between 100Mbps and 400, is that on your Zwift game device at the time? Because it may be that your router’s speed is fine but the wifi to your Zwift game device is a lot less quick. More details would help.
Calibrated to who’s risk tolerance? A dev that has never ridden it or pro that lives close to Nice?
Probably to the car driver, who recorded it.
I was thinking of making a custom curved “screen” for the projector at 125-130° and doing a single projector. Any more and it’s recommended for multiple and blend them together with expensive software. I ain’t got time for that and Zwift probably won’t run it. :sweat_smile:
That’s going to be a slow route down compared to what a good cyclist can do…
Probably, havent done that track so far. But just checked it, might ride it tomorrow.
I have no idea. You’ll have to try it out. The only feedback I can really give is that it didn’t feel ridiculous to me … but what do I know?
Just saying that i realy like this addition. If zwift deliver on regular (say at least two), new routes per month then I’d likely pay for it. If there are not many new routes, its a no and i will likely n wait and see.
I was curious how this was going to work out on a 21:9 monitor. That’s gonna be a no from me. Glad some people are enjoying it.
+1, my number one request as well
After 5 minutes of riding I saw this. iPhone 12 Pro Max
Thanks. These speeda are from the zwift device, which sits next to the main mesh node. The fluctuations is from the ISP: slow at peak times, fast on quiet times of the day. But usual speed does not exclude a temporary network issue. I should monitor the connection independently next time.
This is an issue of not having enough download bandwidth. You need to measure the speed of your device when it’s in the same position as you use for Zwifting (try Speedtest). Possibly a local wifi issue if your router’s download speed is fine.
Zwift say you need a minimum of 50Mbps.
Does anyone know where the downloaded Z+ video files end up on your local device storage? I run Zwift on a gaming laptop (Windows 10). I was poking around in my %USERPROFILE%\AppData\Local\Zwift directory, and found a subdirectory named ‘mochi’, with a timestamp corresponding to the last time I used Zwift and trialed Zwift+, and there’s a lot of files stored in there, a little over 1 GB worth!
I’d like to remove any Zwift+ video content files after I am finished completing the corresponding route, I can’t see any valid reason why I would need to keep any of that data around if I am not planning to continue using Z+ after the free trial…
[Some lines copied from my command line window]
11/02/2026 07:02 PM <DIR> mochi
Directory of C:\Users\Ray\AppData\Local\Zwift\mochi
[not displaying long list of files]
110 File(s) 1,101,393,464 bytes
I rode this track today. And as I thought: Speed seems to be depending on what the recording car did. At tighter corners the speed slowed much more down than the others.
But whats more confusing: The watts dont reflect the speed. I was descending at around 70kmh with 142W. As I did some intervals, i started one with 320W and the speed was: 71kmh
Very strange.
