Getting Strava to automatically mark rides with a certain bike?
Is there a way to get Strava to automatically mark Zwift rides with a certain bike, and then have Strava mark real world rides with a another bike? I have a separate bike for each, and would like to keep track of the miles separately. I also wish to separately monitor the wear on the components and chain waxing intervals. My current work around is to default all my rides to a certain bike and when I do an outside ride, I have to manually change it. This is becoming tedious.
https://www.activityfix.com/ can do this I expect.
You can set it to change gear based on certain criteria.
e.g.
When:
…and then use https://maintrack.app (Maintenance tracker add on for Strava) to remind you of when to perform service and to track what you did.
it takes like 2 seconds to select which bike you did the ride on after completing an activity xD
Why do something manually all the time when you can automate it? I ride frequently. Looks like activity fix will do the trick.
I like activity fix, I use it to put my lifetime stats in the description as well as a monthly summary of all activities in the second line
Screenshot 2022-06-03 184243
They really should add this feature. I ride both indoors and outdoors. I will forget to update the bike every now and then.
Hi @bogardon
Try this: ActivityFix.com
