I can’t open The at Home Cycling & Running Virtual Training App or the web pages for individual events, looks like I get a redirect loop between urls with and without “/uk/” in them.
Same here. Cannot log in anymore on Zwift.com.
Redirect checks:
302 Moved Temporarily
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
/events
/eu-de/events
Problems found:
- Too many redirects . Please try to reduce your number of redirects for The at Home Cycling & Running Virtual Training App. Actually you use 19 Redirects. Ideally you should not use more than 3 Redirects in a redirect chain. More than 3 redirections will produce unnecessary load on your server and reduces speed, which ends up in bad user experience.
- You use a 302 redirect . This means, that the actually content is temporary not reachable and will come back soon. To use a 302 redirection for generally moved pages is a bad idea. Search engine bot might not follow it or handle it as temporary. For SEO this is also a bad idea, because no link juice will be transferred to the linked page.
Seems to work fine again now.
