I’d like to see an on-screen indicator of drafting effectiveness. Something that shows graphically where you are in the drafting zone, with maybe the addition of a ‘sweet spot’ indicator showing where the draft effect is greatest.
The current solution that hides any drafting notice once you get in the draft is less than effective.
Because Zwift does not have identical feel to real world drafting, an indicator like this could help users understand and control drafting dynamics better.
+1. The “close the gap” indicator is intrusive, but once you’ve closed the gap you’ve got no indication if you’re still in the draft or how effective it is, Plus you can come out the front and there’s no indication that you are no longer drafting.
Please add a current draft strength indicator. A small simple segmented bar running along the bottom edge of the center miles/time data display would be sufficient. This is assuming draft strength is variable over a few levels depending on distance behind another rider. However if drafting is on or off a simple green or red dot would suffice.
